  • Member For: 12y 1m 26d
Hey peeps. My ute was making a few creaking noises in the front and rear.
Tightened up the rear leaf bolts and gave em a spray with WD. Was sweet. Then after a week they start making the noise again.
Then was getting a noise from front end when I turn at slow speed. Say into drive way/ 3 point turn.
Got rack end tightened and still making the noise.
Its really sh*tting me. What could it be? Struts maybe?
Edited by Dagabond
Well there has to be some mechanical reason its doing this. Things dont simply make a noise because somebody named that car Ford does it. Not very clever are ya pal lol.
Anyone got any useful/not stupid answers? Im pretty sure I got the back sorted I found a thread for the leafs
  • I <3 Floods
  • Member For: 13y 8m 13d
Mate read this forum a bit.. You'll see wingnuts response is valid..
But I'd be checking suspension bushes and CV joints..
There are so many things that could be squeaking though..
  • Member For: 16y 8m 10d
I should have been a little more descriptive like SDP but I'm not a troll mate. I was just trying to save you a lot of time and effort. I have an FG and it has squeaked in a handful of different places on and off since I bought it.
Its something that will drive you insane if you let it. Every time I think I have figured one out another will pop up. Once again it comes down to the build quality of these cars which isn't first class.
  • I <3 Floods
I should also mention that when I had an FG ute.. Something in the dash used to squeak as I turned into my driveway.. It was probably the most inconsequential thing.. But I was so focused on that noise every time I turned into my driveway it sent me nuts..
However I was smart enough not to disassemble my dashboard..
  • Spooling Member
  • Member For: 13y 4m 8d
Deck it out with dynamat and pretend nothing is rattling/squeaking :)
  • 2 weeks later...
  • Member For: 11y 8m 6d
Just jack her up and check all the bolts are tight. Might take an hour but might solve a few rattles. Check your sway linkage nuts as these tend to loosen off sometimes.
If your getting creaking it can sometimes be grim and crap in between your spring coils. Ive had this on a Subaru before. Annoyed me no end.
