camdawgs Member 49 Member For: 13y 3m 2d Posted 20/08/13 08:44 AM Share Posted 20/08/13 08:44 AM Hay guys I own a BF typhoon.As of the last few weeks the engine has been running slightly rougher on idle and doesnt sound too flash on idle ( alot louder than normal)....I have also noticed quiet a loud sound that I similar to that of the induction from the turbo but alot louder and it occurs even when not on boost.Have not noticed any performance issues or any other problems just its not sounding too healthy. It is due for an oil change and we will be having a closer inspection at the problem as well as doing the change later this week but it still has only been less than 10000 km since the last change.Any ideas what this sound could be? Link to comment Share on other sites More sharing options...
fatz_f6_typhoon Member 395 Member For: 12y 1m 19d Gender: Male Location: 2145 nsw Posted 20/08/13 09:20 PM Share Posted 20/08/13 09:20 PM Check all your hose clamps could have a boost leak 1 Link to comment Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 17y 10m 23d Gender: Male Location: Canning Vale, W.A Posted 20/08/13 09:55 PM Share Posted 20/08/13 09:55 PM Probably Cooler pipe is loose, as said above you may have a leak somewhere. Check from the throttle body to the intercooler and back to the turbo for loose clamps split pipes/blown off etc. Link to comment Share on other sites More sharing options...
Brooksy-BFXR6T Member 14 Member For: 12y 8m 30d Posted 21/08/13 01:50 AM Share Posted 21/08/13 01:50 AM I know I've done two throttle body to crossover couplings, underneath.. have a look at that, but it usually drops boost too. Link to comment Share on other sites More sharing options...
