mikea1988 Member 102 Member For: 15y 8m 4d Posted 14/08/13 03:44 AM Share Posted 14/08/13 03:44 AM Hey guys I purchased some wheels second hand.20x 235 x 8.5The problem is the stud pattern is 5x 100 I need to get these on my ba mkii xr6tAny suggestions would be greatly appreciated Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/85958-ba-rookie-mistake-new-wheels/ Share on other sites More sharing options...
mikea1988 Member 102 Member For: 15y 8m 4d Posted 14/08/13 04:00 AM Author Share Posted 14/08/13 04:00 AM Offset is 35 all round Link to comment https://www.fordxr6turbo.com/forum/topic/85958-ba-rookie-mistake-new-wheels/#findComment-1415746 Share on other sites More sharing options...
Boganspeed Will do skids for food Silver Donating Members 1,177 Member For: 13y 7m 18d Gender: Male Location: Perth SOR Posted 14/08/13 04:34 AM Share Posted 14/08/13 04:34 AM Snap a few wheel studs off till they fit. (could be a bit wobbly)Otherwise, sell them and buy the right wheels. Link to comment https://www.fordxr6turbo.com/forum/topic/85958-ba-rookie-mistake-new-wheels/#findComment-1415751 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 30d Gender: Male Location: Perth Posted 14/08/13 04:43 AM Share Posted 14/08/13 04:43 AM 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85958-ba-rookie-mistake-new-wheels/#findComment-1415753 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m 28d Gender: Male Location: Far north queensland Posted 14/08/13 04:54 AM Share Posted 14/08/13 04:54 AM http://www.wrxtuners.com/classifieds/showcat.php?cat=7 Link to comment https://www.fordxr6turbo.com/forum/topic/85958-ba-rookie-mistake-new-wheels/#findComment-1415759 Share on other sites More sharing options...
mikea1988 Member 102 Member For: 15y 8m 4d Posted 14/08/13 05:05 AM Author Share Posted 14/08/13 05:05 AM Is there any spacers or anything that can change the stud pattern to make them fit?? Link to comment https://www.fordxr6turbo.com/forum/topic/85958-ba-rookie-mistake-new-wheels/#findComment-1415763 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 29d Gender: Male Location: Probably above atmospheric pressure Posted 14/08/13 05:14 AM Share Posted 14/08/13 05:14 AM (edited) I've read about people using spacers to change bolt patterns but that sounds a bit cowboy to me, surely it would add loads of poke to the wheels and you'd end up with like effective offset of zero or something, hahaha. Probably stress the factory hub bearings being that far, if it even fitted.Things I have looked for when considering rimsPCD (you need 5x144.3)Centre bore size - think falcons are 70.5mm? You can run hub centric rings between the rim and hub to make them sit on the hub properly like factory, these are still legal from what I've read. The reason you need to care about this is if you are buying rims that are designed specifically for another car like Jap imports, as they have a smaller hub size so the rims would need to be bored out, which sounds scary to me and probably illegal.Width combined with offset as you know already. The factory rims from the B series XRs for example are 8" wide with 36mm offset, at least for crappy standard rims, FPV might be different, someone confirm??Weight - factory rims are said to be from about 11 to 15kg from what I've read here. Less mass means better performance in a few areas and less wear and tear in theory.Closely tied to the above is - forged or cast. Forged are strong, light and cost more, cast are cheaper and heavier, on average. There exist rims that at like 8kg even in 18 inch sizes! Much want.Useful sites;http://www.1010tires.com/Tools/Wheel-Offset-Calculator for a quickiehttp://www.willtheyfit.com/ for a flash one which also shows tyre profile changes!Also worth considering legality - overall track width (distance between the outside edges of left and right wheels) laws, tyre/rim size laws... Edited 14/08/13 05:19 AM by -SteveR- 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85958-ba-rookie-mistake-new-wheels/#findComment-1415767 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 3m 3d Gender: Male Location: Vic Posted 14/08/13 05:56 AM Share Posted 14/08/13 05:56 AM Opt 1. Get them drilled. Only an option if there's enough meat so talk to a wheel shop. Opt 2. 25mm spacers with 5x114 in and x100 bolts. That's what I would do. Link to comment https://www.fordxr6turbo.com/forum/topic/85958-ba-rookie-mistake-new-wheels/#findComment-1415778 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 2m 16d Gender: Male Location: A big bridge over a river in South Australia Posted 14/08/13 06:10 AM Share Posted 14/08/13 06:10 AM On 14/08/2013 at 5:14 AM, -SteveR- said: PCD (you need 5x114.3) fixed 3 Link to comment https://www.fordxr6turbo.com/forum/topic/85958-ba-rookie-mistake-new-wheels/#findComment-1415781 Share on other sites More sharing options...
mikea1988 Member 102 Member For: 15y 8m 4d Posted 14/08/13 07:55 AM Author Share Posted 14/08/13 07:55 AM Maybe a 5x100 adapter to 5x 114.3Current offset is 35 Link to comment https://www.fordxr6turbo.com/forum/topic/85958-ba-rookie-mistake-new-wheels/#findComment-1415805 Share on other sites More sharing options...
