FGED UP Member 28 Member For: 13y 10m 11d Gender: Male Posted 18/08/13 10:55 AM Share Posted 18/08/13 10:55 AM my ute is tuned to 98, the other day my old man took it out filled with 91 unknowingly. I went out the next day and could hear a ticking noise took it to my tuner straight away. He said someone filled your car up with 91(think he called it pinging), had I giving it a good squirt it could have snapped pistons or put holes in the engine. Link to comment https://www.fordxr6turbo.com/forum/topic/85917-running-919598-octane-will-a-tune-remove-the-flexibility/page/2/#findComment-1416919 Share on other sites More sharing options...
wa g6et Member 657 Member For: 13y 10m 15d Gender: Male Location: Perth NOR Posted 18/08/13 11:23 AM Share Posted 18/08/13 11:23 AM Maybe a tuner can jump in here to answer the question.I too would like to know how come a Late model camira tuned wirh VCM or the like has "91 and 95 fall back tables" buit in the tune. Can someone explain what this means and how come our turbos don't do the same when tuned? Link to comment https://www.fordxr6turbo.com/forum/topic/85917-running-919598-octane-will-a-tune-remove-the-flexibility/page/2/#findComment-1416926 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 22d Gender: Male Location: @ my laptop Posted 18/08/13 11:27 AM Share Posted 18/08/13 11:27 AM commodores once tuned do not always have the ability to run on low octane fuel, it depends on how they are tuned, but a Late model camira has wto different spark tables that it will work from depending on knock events, the falcon ecu just pulls spark at a set amount based on a knock even Link to comment https://www.fordxr6turbo.com/forum/topic/85917-running-919598-octane-will-a-tune-remove-the-flexibility/page/2/#findComment-1416927 Share on other sites More sharing options...
wa g6et Member 657 Member For: 13y 10m 15d Gender: Male Location: Perth NOR Posted 18/08/13 01:34 PM Share Posted 18/08/13 01:34 PM Thanks Ratter. Is it possible at all to have these multiple spark tables in our Fords? Link to comment https://www.fordxr6turbo.com/forum/topic/85917-running-919598-octane-will-a-tune-remove-the-flexibility/page/2/#findComment-1416945 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 4m 24d Gender: Male Location: Probably above atmospheric pressure Posted 18/08/13 02:25 PM Share Posted 18/08/13 02:25 PM Think you'd need a whole new ECU? If I'm reading things right. Link to comment https://www.fordxr6turbo.com/forum/topic/85917-running-919598-octane-will-a-tune-remove-the-flexibility/page/2/#findComment-1416950 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 22d Gender: Male Location: @ my laptop Posted 18/08/13 11:36 PM Share Posted 18/08/13 11:36 PM no it can't be done to our ecu's, we do not modify things but adjust what is already there, we can not add to it Link to comment https://www.fordxr6turbo.com/forum/topic/85917-running-919598-octane-will-a-tune-remove-the-flexibility/page/2/#findComment-1416988 Share on other sites More sharing options...
