Tax Money Comming!
nathanway
  • Member For: 13y 6m 14d
wow wasn't expecting that, sorta bum's me out so you think 350 with out doing the oil pump is ok or is that with doing it, if it is, its a Lota extra money and turbo lag for 20rwkw, im keen as to get at least 500rwhp but it has to be safe'ish im not gonna be flogging it at the track just a squirt hear and there and the odd trip to the drags but in saying that if its gonna cost $4000 for 330kw and $10000 to get to 350kw I think ill be sticking with the standard turbo,
comm'on guys what does it take to hit the 375-400 mark with out paying $2.50per L + freight for for a 44gallon barrel of e85
GTX has billet compressor wheel
injectors, fuel pump, oil pump, surge tank $1500? = $1600. Oil pump gears installed will be about $1600
Just tune for 98 and aim for 350rwkw.
  • Dropping a turd
  • Member For: 17y 3m 24d
No you mentioned oil pump. I have a manual so mine is done. Its not a necessity. Iam just saying. If you aim for 350 you wont be disappointed. Its not all about peak power , its delivery and midrange.
  • Member For: 16y 11m
Don't worry bout the oil pump x2.
Full exhaust, cooler, decent injectors like 1000s ($700-800) and a surge or intank($1000 for a plaz with single 044) , and a Ba-f turbo ported with actuator(seen one for $600, then 1k for port and
Actuator and fitting), and valve springs $900
Edited by Henz
  • Member For: 13y 4m 17d
post-48105-0-90049100-1376217998_thumb.j
Now I know that you should take dyno results with a grain of salt, but, yeah, this thing will peel 295 semi's like there made of butter (it is a ute to be fair)
06 BF;
Pazmaman 1200hp cooler, plenum & surge tank(044 main+walbro lift)
Battery relocated, 4" cold air intake
Hiflow turbo & 12lbs actuator + modified wastgate
4" dump, 5" cat, twin 2.5" xforce
Upgraded valve springs & injectors + a good tune
plus all the other sh*t to pin it to the road, but that much should get you close to where you want to be.
^ very similar to my old ute, used to blow 295s rolling from 100.
