  • Member For: 11y 11m 16d
Hello, I need some help if anyone cares to give any info on my turbo problem. I have a BA XR6 turbo ute mk2 that has an intercooler, intake pipework, 3.5ëxhaust. I fitted new 60lb deka injectors and loaded my bpracing X3 60lb 11psi tune today (I know using these tunes can be like playing russian roulette and had planned on not driving it until I get it dyno tuned but I just went for a zip down the road).The car idled fine and drove well unti I hit WOT the turbo made an uneven whooshing noise and then made what sounded like a mega blow off valve noise(not metallic), after the noise I could hear the turbo spooling up but it also made a sound like the boost was escaping and the cars performance is that of an N/A vehicle. I will look tomorrow at the turbo and piping but it's too dark now was just wondering if anyone has experienced this problem.
https://www.fordxr6turbo.com/forum/topic/85906-help-my-turbo-is-not-well/
  • Dropping a turd
  • Member For: 17y 6m 20d
More than likely you blew a hose off. Dont drive it and check them all tomorrow.
  • Member For: 17y 5m 23d
Is that tune you have one that is designed for 60lb dekas?
Thanks for the help, I got under there this morning and found the pipe leading into the bottom of the turbo (air outlet) had blown right off. The pipe only had a spring clamp so will replace it with a threaded hose clamp to hopefully give me a better hold. Has anyone here tryed the external NIZPRO overboost valve????????? I would like to avoid splitting the turbo to be sent off and ported. And also can you replace the actuator without pulling the turbo off????. I will do some searches tonight as I'm sure theres threads on all of these but don't have any time today and would greatly appreciate any input.
  • Dropping a turd
You could use the Nizpro valve to bleed off boost. Yes you can change the actuator on the car but is quite difficult.
  • Moderating Team
  • Member For: 22y 3m 16d
Nizzer overboost valve not required. ^^^^^^^^^ edit: wow that's the first time ive ever seen one in use!!!
Yep you can replace the actuator without dropping turbo, but im guessing you havent finished modding; so just drop the turbo, get the wastegate port opened up a bit, new flapper, new actuator, and never worry about boost issues ever again.
do it once, do it right! will save you in the long run.
Edited by ms700
aarons post
Yeah I think I might go the way of porting I've gone this far and I have to fit 4 new turbo/exhaust manifold studs anyway after spending $212 for 4 studs,4 nuts and a s.steel gasket from Nizpro.
