discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 1d Gender: Male Location: Probably above atmospheric pressure Posted 10/08/13 02:01 AM Share Posted 10/08/13 02:01 AM Yeah wow I would have thought that the aeroflow rail would fit as a starting point. Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/page/2/#findComment-1414480 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 2d Gender: Male Location: Perth Posted 10/08/13 02:04 AM Share Posted 10/08/13 02:04 AM These rails are the samehttp://www.injectorsonline.com/indivprod.php?cid=82 Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/page/2/#findComment-1414482 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 2m 2d Gender: Male Posted 10/08/13 02:17 AM Share Posted 10/08/13 02:17 AM Love my Atomic rail and was a very easy install with perfect fitment of injectors.Keeps the fuel cooler as well as it doesn't heat soak anywhere near as much as the stock B/F series rails....not 100% sure if this helps anything but cant hurt. Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/page/2/#findComment-1414493 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 4m 25d Gender: Male Location: Sydney Posted 10/08/13 02:19 AM Share Posted 10/08/13 02:19 AM piks of atomic rail/setup? Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/page/2/#findComment-1414495 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 2m 2d Gender: Male Posted 10/08/13 02:27 AM Share Posted 10/08/13 02:27 AM The regulator is no longer mounted to rail as I was paranoid about it coming loose/vibrations so moved it to where B series standard air box is bolted to near strut passenger side.regulator is a A1000 Aeromotive.Gates Barricade hose(revised stuff) used throughout. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/page/2/#findComment-1414498 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 2m 2d Gender: Male Posted 10/08/13 02:29 AM Share Posted 10/08/13 02:29 AM 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/page/2/#findComment-1414499 Share on other sites More sharing options...
dalts Member 755 Member For: 19y 30d Gender: Male Location: brisbane Posted 10/08/13 03:36 AM Share Posted 10/08/13 03:36 AM I thought the same being aeroflow it should be of some decent quality how I was wrong.it will be seeing the bin shortly!Lee 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/page/2/#findComment-1414513 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 2m 4d Gender: Male Location: Sydney Posted 10/08/13 03:55 AM Share Posted 10/08/13 03:55 AM On 10/08/2013 at 2:29 AM, Skids4kids said: The regs ate quieter if you can mount it to the motor somewhere 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/page/2/#findComment-1414521 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 10m 14d Gender: Male Location: Melb Posted 13/08/13 01:48 AM Share Posted 13/08/13 01:48 AM You may not be able to run the connector on the bottom either with the adaptor.. (it almost looks like it fouls with the inlet runner in the pic) Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/page/2/#findComment-1415385 Share on other sites More sharing options...
