E85, Id1000's & Aftermarket Rail - Leaking Fuel
  • Member For: 17y 1m 29d
Yeah wow I would have thought that the aeroflow rail would fit as a starting point.
  • in the mid....not the bum like some
  • Member For: 11y 8m 30d
Love my Atomic rail and was a very easy install with perfect fitment of injectors.
Keeps the fuel cooler as well as it doesn't heat soak anywhere near as much as the stock B/F series rails....not 100% sure if this helps anything but cant hurt.
The regulator is no longer mounted to rail as I was paranoid about it coming loose/vibrations so moved it to where B series standard air box is bolted to near strut passenger side.
regulator is a A1000 Aeromotive.
Gates Barricade hose(revised stuff) used throughout.
