  • Member For: 17y 8m 6d
Gday,
I'm hoping for some help.
I've fitted ID1000 injectors with the blue Top Hat adapters, into an Aeroflow BA/BF billet fuel rail.
Problem is, the o-rings on top hats dont seat into the fuel rail far enough, so I have fuel spraying out from between rail & top of cap. Top hat o-ring sits about 1.5mm into the fuel rail.
The purple Top hat adapter caps look only millimetres longer, so dont look like they will seat right into the rail either. ...and the standard long length tapered adapters (for 1/2 size injectors) are too long.
Has anyone else run into this issue?
Cheers!
post-12786-0-01144600-1376027737_thumb.j
  • Member For: 17y 5m 3d
  • Member For: 18y 11m 1d
had a ba in the shop once that had a rail similar looking to yours, it pushed a siemens 60 lb injector out far enough to have a major fuel leak , owner was actually very lucky he did not have a fire, replaced the rail with a P/wes one and all was good
  • Member For: 18y 11m 2d
I have the aeroflow rail and its a rubbish fitment its been modified a few times to stop leaks if I hadn't spent that much time on trying to get it to fit I would have thrown it in the bin!
Lee
Thanks guys. Yep my injector popped out also..must be the rail (plenty of id1000's getting around). Had a snort one on earlier with same problem.. Hoping this one would be trouble free. I'll see what I can do to fix it, or rail #4 on the way.
The top hats give one more possible place to have a leak spring, but shouldn't be an issue if fitted properly (single piece 968's didn't leak though).
Not supposed to be crooked but ended up like that as heaps of play.
Still, I'll blame the rail not injectors.
Thanks for your input
  • Moar Powar Babeh
  • Member For: 19y 7m 5d
Bin, the rail. I had the same issue with a rail similar to that from injectors online. Get a name brand rail either process west or plasma man.
  • Moderating Team
  • Member For: 22y 2m 28d
This is how TRYHRD caught fire on the rollers at Summernats 19
hit the rev limiter, shook all the injectors, a o ring popped out, whooska up she went.
  • Menace
  • Member For: 14y 6d
Those aeroflow fuel rails are sh*t.. Seen 2 car try to use them, both had pita fuel leaks that gave kn'headaches.
It's one of those times you'd love to meet the genius who built it and clobber them over the head with the pos.
Edited by Kroozin
  • flame magnet
  • Member For: 16y 11m 12d
good to know that these are not the go... they all sound excellent in the write ups. could this be a sticky so no one else has issues like this?
