RDCULS New Member 16 Member For: 17y 10m 5d Posted 09/08/13 06:03 AM Share Posted 09/08/13 06:03 AM Gday,I'm hoping for some help.I've fitted ID1000 injectors with the blue Top Hat adapters, into an Aeroflow BA/BF billet fuel rail.Problem is, the o-rings on top hats dont seat into the fuel rail far enough, so I have fuel spraying out from between rail & top of cap. Top hat o-ring sits about 1.5mm into the fuel rail.The purple Top hat adapter caps look only millimetres longer, so dont look like they will seat right into the rail either. ...and the standard long length tapered adapters (for 1/2 size injectors) are too long.Has anyone else run into this issue?Cheers! Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/ Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 3d Gender: Male Location: Probably above atmospheric pressure Posted 09/08/13 06:45 AM Share Posted 09/08/13 06:45 AM Is that supposed to be crooked? Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/#findComment-1414277 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m Gender: Male Location: @ my laptop Posted 09/08/13 06:47 AM Share Posted 09/08/13 06:47 AM had a ba in the shop once that had a rail similar looking to yours, it pushed a siemens 60 lb injector out far enough to have a major fuel leak , owner was actually very lucky he did not have a fire, replaced the rail with a P/wes one and all was good Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/#findComment-1414279 Share on other sites More sharing options...
dalts Member 755 Member For: 19y 1m 1d Gender: Male Location: brisbane Posted 09/08/13 08:22 AM Share Posted 09/08/13 08:22 AM I have the aeroflow rail and its a rubbish fitment its been modified a few times to stop leaks if I hadn't spent that much time on trying to get it to fit I would have thrown it in the bin!Lee Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/#findComment-1414308 Share on other sites More sharing options...
RDCULS New Member 16 Member For: 17y 10m 5d Posted 09/08/13 08:45 AM Author Share Posted 09/08/13 08:45 AM Thanks guys. Yep my injector popped out also..must be the rail (plenty of id1000's getting around). Had a snort one on earlier with same problem.. Hoping this one would be trouble free. I'll see what I can do to fix it, or rail #4 on the way. The top hats give one more possible place to have a leak spring, but shouldn't be an issue if fitted properly (single piece 968's didn't leak though).Not supposed to be crooked but ended up like that as heaps of play.Still, I'll blame the rail not injectors.Thanks for your input Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/#findComment-1414315 Share on other sites More sharing options...
dalts Member 755 Member For: 19y 1m 1d Gender: Male Location: brisbane Posted 09/08/13 09:41 AM Share Posted 09/08/13 09:41 AM It's definately the rail even the brackets didnt line up on mine they have been drilled out and it's still a nightmare.Lee Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/#findComment-1414328 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 4d Gender: Male Location: Perth Posted 09/08/13 12:38 PM Share Posted 09/08/13 12:38 PM Bin, the rail. I had the same issue with a rail similar to that from injectors online. Get a name brand rail either process west or plasma man. Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/#findComment-1414383 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 4m 27d Gender: Male Location: Sydney Posted 09/08/13 11:35 PM Share Posted 09/08/13 11:35 PM This is how TRYHRD caught fire on the rollers at Summernats 19hit the rev limiter, shook all the injectors, a o ring popped out, whooska up she went. Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/#findComment-1414440 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 2m 6d Gender: Male Location: Sydney Posted 10/08/13 12:11 AM Share Posted 10/08/13 12:11 AM (edited) Those aeroflow fuel rails are sh*t.. Seen 2 car try to use them, both had pita fuel leaks that gave kn'headaches.It's one of those times you'd love to meet the genius who built it and clobber them over the head with the pos. Edited 10/08/13 12:14 AM by Kroozin 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/#findComment-1414451 Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 17y 1m 11d Gender: Male Location: adelaide hills- 'race air' central Posted 10/08/13 01:17 AM Share Posted 10/08/13 01:17 AM good to know that these are not the go... they all sound excellent in the write ups. could this be a sticky so no one else has issues like this? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85898-e85-id1000s-aftermarket-rail-leaking-fuel/#findComment-1414470 Share on other sites More sharing options...
