PH1LLO Member 56 Member For: 12y 5m 17d Gender: Male Location: SE suburbs, Vic Posted 08/08/13 07:11 AM Share Posted 08/08/13 07:11 AM (edited) Hey all. Apologies in advance for the long story. I tend to be thorough. I'm in the market to buy a new car, I had pretty much narrowed it down to a Turbo Territory (my other thread) due to it uses. But after countless hours of reading on this forum the idea of a FG Ute has popped up. Thought I'd post up asking a few qs and tell you what I'm after. I've had Holdens and hilixus all my life so still learning the ford way. I share a Centurion wake boat with a mate that weighs in somewhere around the 2200kg mark. The boat is on a reasonably well balanced random trailer with cable brakes. I'd estimate ball weight around 140kg I can't afford 2 cars, so I'm chasing the best of both worlds in which is a car that can tow the boat, but also have 250+kw. My mate who I share the boat with has a car that can tow, but we wanna share it around a bit. We head away on average once a month. So I would probably be towing it 6-7 weekends a year. (it's about 2hr drive. Rowville to Eildon). I'm aware the territory would do it better. But I'd prefer the Ute more as a daily which Is what it'll be used for 95% of the time, and I've read a lot of dramas about the terry turbo. So my questions.. -If it fit up the Hayman Reese class 4 2300kg bar to the Ute. Do you think it will be ok to tow it? -would the ZF auto require/benefit from an upgraded transmission? -anything else I should know re: towing with the FG Ute? Happy to go down the upgraded suspension path if required. Also Is axle tramp / bent axles an issue I should worry about? Thanks heaps in advance for your replies! Phillo. Edited 08/08/13 07:19 AM by PH1LLO Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 10m 25d Gender: Male Location: Christchurch, New Zealand Posted 08/08/13 10:33 AM Share Posted 08/08/13 10:33 AM In the towing capacity thread someone mentioned a zf giving up towing a malibu. So going by that although the weight is within the limits it still probably isn't a good idea.To be honest with that weight your diesel trucks are the way to go really. The utes do tow well but I wouldn't want to do that as often as you want with one. Link to comment Share on other sites More sharing options...
PH1LLO Member 56 Member For: 12y 5m 17d Gender: Male Location: SE suburbs, Vic Posted 08/08/13 11:46 AM Author Share Posted 08/08/13 11:46 AM In the towing capacity thread someone mentioned a zf giving up towing a malibu. So going by that although the weight is within the limits it still probably isn't a good idea.To be honest with that weight your diesel trucks are the way to go really. The utes do tow well but I wouldn't want to do that as often as you want with one.Cheers mate, ill try find that thread.Another thing I just thought of, reading a few things about turbos always being on boost and getting hot. Would a boost gauge and/or EGT gauge to monitor this help? Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 1m 21d Gender: Male Posted 08/08/13 08:19 PM Share Posted 08/08/13 08:19 PM Buy a sedan 1 Link to comment Share on other sites More sharing options...
PH1LLO Member 56 Member For: 12y 5m 17d Gender: Male Location: SE suburbs, Vic Posted 09/08/13 12:38 AM Author Share Posted 09/08/13 12:38 AM Don't you need the leafs to tow the 2300kg? Link to comment Share on other sites More sharing options...
southside Member Member 868 Member For: 15y 11m 10d Gender: Male Location: Radelaide.. Real Posted 09/08/13 01:43 AM Share Posted 09/08/13 01:43 AM In the towing capacity thread someone mentioned a zf giving up towing a malibu. So going by that although the weight is within the limits it still probably isn't a good idea.To be honest with that weight your diesel trucks are the way to go really. The utes do tow well but I wouldn't want to do that as often as you want with one.Correct, I'm sure it was my post where I mentioned my mates 2010 FG XR6T ZF gave up after reversing the Malibu wake setter into the shed. My 2012 SR5 hilux was still the best towing car 1 Link to comment Share on other sites More sharing options...
PH1LLO Member 56 Member For: 12y 5m 17d Gender: Male Location: SE suburbs, Vic Posted 09/08/13 01:43 AM Author Share Posted 09/08/13 01:43 AM (edited) Does anyone know how I edit my original post? I typed it on the tablet but submitting it got rid of all the paragraphs? (there is no edit button next to the quote and multi quote on my original post?) Edited 09/08/13 01:44 AM by PH1LLO Link to comment Share on other sites More sharing options...
southside Member Member 868 Member For: 15y 11m 10d Gender: Male Location: Radelaide.. Real Posted 09/08/13 01:44 AM Share Posted 09/08/13 01:44 AM Does anyone know how I edit my original post? I typed it on the tablet but submitting it got rid of all the paragraphs?U can't edit it now, usually only have a 5-10 minute window after originally posting your topic where u can edit it Link to comment Share on other sites More sharing options...
PH1LLO Member 56 Member For: 12y 5m 17d Gender: Male Location: SE suburbs, Vic Posted 09/08/13 01:46 AM Author Share Posted 09/08/13 01:46 AM U can't edit it now, usually only have a 5-10 minute window after originally posting your topic where u can edit itSeems a bit odd?Correct, I'm sure it was my post where I mentioned my mates 2010 FG XR6T ZF gave up after reversing the Malibu wake setter into the shed. My 2012 SR5 hilux was still the best towing car how often was he using it to tow mate? Link to comment Share on other sites More sharing options...
southside Member Member 868 Member For: 15y 11m 10d Gender: Male Location: Radelaide.. Real Posted 09/08/13 01:49 AM Share Posted 09/08/13 01:49 AM on average twice a month, driving no more than 500m to and from his house to ramp. Also, the turbo's dont like the added boost pressure it demands when towing heavy loads, and your standard tune will most likely display and engine warning light due to an unusual amount of flow past your O2 sensors, which makes the car think it's not running correctly Link to comment Share on other sites More sharing options...
