  • Member For: 17y 4m 30d
Hahaha, +1. I no longer care as much as I did when my car was stock and I made that graph :)
  • Member For: 19y 8m 12d
Why would it run lean? The ford speed density tables are mapped regardless of boost pressure. Its only when you exceed the measuring capacity of the factory map sensor is when it can become lean.
The only problem you need to worry about is the point in which it pulls down in the next gear, it doesn't ping. Most tuners know this and create somewhat of a timing hole at this RPM point, But there's better ways to handle this.
