  • Member For: 19y 9m 30d
Yes. but at this extreme mick, there is signs of idle problems and stalling problems.
The fuel trims Do correct it, but its more the problem that the ID1000/Bosch 1000cc injectors have trouble opening at that fuel pressure is what I've noticed.
Edited by Headsex
  • Member For: 19y 14d
  On 15/08/2013 at 8:43 AM, F6Fury said:
And Also the fact that once boost is introduced you will have close to 120psi at the rail and then fuel temp issues start coming into play
not if it's a back up caused by the reg not flowing enough
ID's and possibly most ev14 injectors will operate to around 7 or 8 bar, but scaling needs to be done correctly
Once you start using fuel to where the reg isn't backing it up the fuel pressure will actually drop.
Mick, I've seen some spec sheet around saying they won't open at around 100-110
  • Member For: 14y 7m 22d
  On 15/08/2013 at 7:05 AM, ratter said:
the tune can be altered for the high pressure so in theory nothing may be wrong, fuel trims would confirm this
By being told nothing was wrong tuner just wanted to keep putting idle up and once got to a certain point if still stalling still wanted to try and find other problems
Anyway cars getting retuned 2moro and for the first time since it was first tuned 4 weeks ago I might be able to enjoy it without worries
my posts are not coming across clearly, it should idle fine etc if set up correctly, Bels G6ET idles at 550 rpm with 1000cc injectors, high fuel pressure at idle can be tuned around, but correct pressure is ideal, you will not have 100 psi once the revs come up unless your pressure reg is stuffed and lastly, your afrs in your tune were good enough to not cause any power issues, retuning may fix idle issues but not power issues unless they suddenly work out they have done something incorrectly and rectify it :)
  • Member For: 13y 9m 30d
I was running 120psi AT IDLE! Perfect idle and no issues were present! This was with twin 044's and stock rail & reg. so apart from the obvious extremely high pressure everything seemed fine car drove as normal. In saying this I bet the injectors weren't loving it :)
