  • Member For: 14y 6m 1d
I've been noticing a slight weird behavior going on with my BFii XR6T Sedan. Car is fairly stock, mild tune/mods, LPG, 70,000km old Bilstiens, Front lower control arm bushes and rear sway bar bushes done, 200,000km total on it.
Travelling on the freeway, then giving it stick, as the box shifts down and car starts to accelerate the rear seems to 'shift' or move slightly sideways. I'm pretty sure it's a recentish thing. Can't see any obvious issues or anything loose/warn, wondering what could possibly cause this?
https://www.fordxr6turbo.com/forum/topic/85824-squirmyness-from-the-rear-end/
  • Member For: 21y 8m 7d
Have you checked the rear wheel bearings and the tightness of the main hub nuts each side? My previous FG did the same as you describe and it was a loose nut.
Benny.
  • Bronze Donating Members
  • Member For: 12y 6d
Benny.
Yep checked this. Had the left rear hub nut come loose once ages ago and it felt weird. Scary one could move the whole wheel on the hub/suspension. Both are tight as now. The sensation was also apparent this weekends camp trip. Fully loaded up car, 3 dogs,2 people, boot epic load, trailer stacked to hilt + 2x dirt bikes. Almost feels like it lists back from front left to rear right. Could be a non obvious bush that's worn. Will have to get it up on a hoist or something I think.
  • Moar Powar Babeh
  • Member For: 19y 6m 20d
The left rear hub nut doesn't affect bearing preload, it only retains the cv joint/half shaft in the hub. If that was an issue before start there.
  • Member For: 12y 8m 21d
^thorght it did affect preload? when I had ford press new bearings in they said make sure the nuts done up corectly as it affects the bearing...I also had the left rear come loose soon after causeing a knocking sound and loosness in the rear of the car. also could wobble the wheel. once tightened up its fine now.
  • 1 month later...
The cause, right rear outer toe arm bush is shot, one can move the wheel around by hand haha. As per my other thread it needs quite a few bushes done.
