  • Member For: 12y 3m 4d
Cheers BenDoCo! Was looking for a new thread :P
Thanks for the detailed reply Henz! My mechanic said he wants to replace something on the turbo, can't remember what it was called but he said at higher power it isn't strong enough and ends up staying open or something. So not sure if that would increase the turbo limits or not
There is probably not much point going e85 if I am at the limits of the stock turbo, but I will definitely get id1000s installed, thanks mate!!
  • Member For: 18y 11m 8d
have you spoken to your tuner about your mods?
we have seen many cars done by mechanics that think they know what they are doing, only to mess it up and the owner ends up paying the mechanic to do the job and then having to pay the tune shop to fix it up, some mechanics are really good, some are good for changing oil.
  • Member For: 17y 1m 15d
Ratter, I haven't organised a tuner yet, but he wanted to take it to the guy around the corner from him who, he usually gets to do the tune. He said will be $700 which I presume is around the standard. He reckons with my mods I should just see 300rwkw but I'm not sure if he lowered his expectations because he thought that was the max that I wanted, not the min. I want to see if he can get it down to pitlane though, if it's not too far from him. I got put on to the mechanic from my mates boss who go his ba turbo worked by him, as he was pretty decent and reasonably priced
Haha thanks Henz
Ild be getting more info man, the tuner makes or breaks these cars!
Normally, but when cooler pipes start blowing off, or other issues pop up it falls back to you and your mechanic to rectify and becomes a head f*ck.
I drop the car to Mick@Pitlane to fit parts and then you know everything will be 100%. And trust me my cars put him through hell :)
  • You've changed man....
  • Member For: 14y 4m 8d
stage 2 from micks group buy definately. and make sure them 60lb are not drilled...
just go id1000.. the price is right.
my advice was not so you bring the car to me, but at the end of the day if you, or somebody you have got to do your setup, are either of you going to take responsibility if it doesn't perform? everything it seems these days fall in the lap of the tuner when it comes to blaming some one if it does not work to how somebody thinks it should, or there are issues based on parts you have used.
  • Member For: 16y 3m 2d
+1 for taking it to a tuner/mechanic shop. dont waste your time and money by taking it to 2 different places. it'll only end in tears which something goes wrong.
if you're not doing the mechanical work yourself, you're a LOT better off by taking it to a "drive in drive out" kinda place. :)
