fgvic Member 27 Member For: 11y 11m 2d Posted 31/07/13 01:29 PM Share Posted 31/07/13 01:29 PM Hey guys, finally saved up to start doing some mods! Its a manual series 1 FG xr6t. I am aiming to start at over 300rwkw with these mods, but may want to go higher after depending on how it feels. I want it looking as stock at possible (black intercooler ect.) and to stay reliable. I will be trying to occasionally get it on the drag strip and track after doing mods too, so want a half decent set up! My plans are 4" intake + battery relo kit (already got)60lb injectorshi flow catintercooler and pipingxcal3With the 60lb injectors and xcal, my mechanic said he can get it for 1100$Does that sound reasonable? I'm not sure what brand injectors but yeahWith the intercooler, I was planning on a stepped intercooler. But I didn't know the previous owner had already cut out the support bar to install an intercooler. Should I take it to a panel beater and get them to replace it? or should I just be happy that it is already remove and chuck in a big intercoolerI would want the ProcessWest stage 1 in the group buy if I was getting it put back in.Or I would think ProcessWest stage 2 (complete kit) or plazmaman stage 2 kit, if leaving it outWhat would you guys do?I was reading on here that the venom cat seems to be the way to go. Are they any good? I mentioned it to my mechanic but he reckons they are no good. Also should I try and include a 4" dump? like the plazmaman one for $950?Thanks for any questions you may be able to answer!!Here are the links to the products:ProcessWest stage 1: http://www.processwest.com.au/index.php/products/ford/fg-products/stage-1-intercoolerProcessWest stage 2: http://www.processwest.com.au/index.php/products/ford/fg-products/stage-2-intercoolerPlazmaman stage 2: https://www.plazmaman.com/shop_itemdetail.php?itemid=79&cate=55Cat and dump: http://www.processwest.com.au/index.php/products/ford/fg-products/stage-2-intercooler Link to comment Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 11y 8m 27d Gender: Male Location: A big bridge over a river in South Australia Posted 31/07/13 01:41 PM Share Posted 31/07/13 01:41 PM sounds like you're planing things out pretty well.....good job.With the intercooler, if you went the larger 1, I'm wondering if it will just be over-kill though, and if you joined the group buy, do you have to get the bar thingy replaced? Link to comment Share on other sites More sharing options...
fgvic Member 27 Member For: 11y 11m 2d Posted 31/07/13 01:57 PM Author Share Posted 31/07/13 01:57 PM (edited) Thanks BenDoCo! This forum is a great helpYeah I was thinking it may be overkill.. But at the same time, if I end up going turbo upgrade and full/cat back exhaust it may come in handy going the larger oneAnd the usual RRP of both ProcessWest intercoolers are identical.. so pricing difference between all three is about 400$So getting the bar put in, to get the cheaper cooler may infact end up costing more.. Wish it was still in, would of made things ALOT easier haha!EDIT:Yeah I think I would have to get the bar put back in, I think that's where set of brackets are mounted Edited 31/07/13 01:59 PM by fgvic Link to comment Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 11y 8m 27d Gender: Male Location: A big bridge over a river in South Australia Posted 31/07/13 02:06 PM Share Posted 31/07/13 02:06 PM I was just about to ask where each 1 mounts but ya beat me. Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 2m 12d Gender: Male Posted 31/07/13 08:21 PM Share Posted 31/07/13 08:21 PM Ratter from Pitlane is doing a group buy on the PW Stepped cooler.. There is a thread started and prices are damn good. Link to comment Share on other sites More sharing options...
sixman Donating Members 600 Member For: 20y 5m 12d Gender: Male Location: Hills District, NSW Posted 31/07/13 09:38 PM Share Posted 31/07/13 09:38 PM I was trying to decide between the pw stage 1 and 2 coolers. The advantage of stage 1 is no cutting required- not an advantage for you. Stage 2 cools better. Link to comment Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 3m 30d Posted 31/07/13 09:43 PM Share Posted 31/07/13 09:43 PM If u are planning for power down the track and most likely be convinced to put e85 into it, go id1000 injectors. I should have done that but I didn't and can't afford to change everything to suit e85 Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 7m 7d Gender: Male Location: @ my laptop Posted 31/07/13 11:08 PM Share Posted 31/07/13 11:08 PM how long have you had the car for?It should not have passed a rwc with the bar cut out, this would be an expensive fix as it would be a big job for a panel shop to replace the radiator support panel.We have bolt in 5" cats to suit FG, they sell for $500 and we have used the same cat on a BF making 428 rwkw and as mentioned we have a group buy for the stage 1 cooler, we also have a group buy (about to close) for the PWR heat exchanger for the ZF if yours is an auto 1 Link to comment Share on other sites More sharing options...
jacobmitchell92 Donating Members 370 Member For: 13y 8m 24d Gender: Male Location: Perth Posted 31/07/13 11:35 PM Share Posted 31/07/13 11:35 PM I'd suggest Atleast a stage 2 cooler if not go all out to the stage 3 if your planing on taking it further. No point buying a cooler and then having to buy another one soon after. I made that mistake Link to comment Share on other sites More sharing options...
fgvic Member 27 Member For: 11y 11m 2d Posted 01/08/13 12:19 AM Author Share Posted 01/08/13 12:19 AM Pazzo, thanks! Yeah I saw that, would be the go if the support was still thereMy Rod Got Out, If I went E85, would I need to replace fuel lines and pump? or is it just the tune that is changed? Also can you change between E85 and 98? or are you stuck with E85? Just because I have noticed only a few servos sell itRatter, I bought it recently, but the RWC ended on the 11th of July.. I didn't know to look for it and I guess the inspector didn't either. How much roughly would you say? What brand cat is it? And are they in stock? And its manualLooks one of the stage 2's would be better then.. Plazmaman or Process West??Thanks for the help so far guys Link to comment Share on other sites More sharing options...
