_Velocity_ Bronze Donating Members 2,768 Member For: 14y 9d Gender: Male Location: Victoria Posted 28/09/13 12:55 PM Share Posted 28/09/13 12:55 PM Have you checked out the fuel regulator? Link to comment https://www.fordxr6turbo.com/forum/topic/85814-strange-idle-after-engine-swap/page/4/#findComment-1428718 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m Posted 28/09/13 08:39 PM Author Share Posted 28/09/13 08:39 PM That's next, forgot to pull off vac hose while its running to see if its leaking fuel. Seems to overfuel on all injectors though as there is fuel/oil build up in each runner. I'm assuming something is telling PCM to add more fuel at idle. No codes (haven't tried ford though to see if they find codes on their system). Link to comment https://www.fordxr6turbo.com/forum/topic/85814-strange-idle-after-engine-swap/page/4/#findComment-1428736 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m Posted 29/09/13 12:00 PM Author Share Posted 29/09/13 12:00 PM So not fuel reg, and definitely can't find any vac leaks. Put a manual vac gauge on and car sits steady at 14hg vac. Doesn't fluctuate at all which points to timing issue?? Would it have anything to do with the cam solenoids maybe not working properly at idle?? They can gum up apparently and cause issues. I'm stumped. Link to comment https://www.fordxr6turbo.com/forum/topic/85814-strange-idle-after-engine-swap/page/4/#findComment-1428968 Share on other sites More sharing options...
BRK Member 361 Member For: 13y 4m 21d Gender: Male Location: Perth Posted 29/09/13 12:15 PM Share Posted 29/09/13 12:15 PM A long shot - but is it the brake booster or brake booster hose - (Cheap and easy to test). Link to comment https://www.fordxr6turbo.com/forum/topic/85814-strange-idle-after-engine-swap/page/4/#findComment-1428973 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m Posted 30/09/13 09:30 AM Author Share Posted 30/09/13 09:30 AM Did brake booster checks and all seems fine. Sooo strange, to drop that amount of hg would have to mean a pretty serious leak. Don't know what else to look at. Link to comment https://www.fordxr6turbo.com/forum/topic/85814-strange-idle-after-engine-swap/page/4/#findComment-1429207 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m Posted 03/11/13 07:41 AM Author Share Posted 03/11/13 07:41 AM Ok so have worked out my issue well sort of.... Changed injectors back to stock, loaded stock tune and bam smooth idle and instant fuel at 1.8lt. Dunno y the deka 60's didn't like the fg setup?? Anyway moving on I'm looking at some deatschwerks 740cc injectors, any body used them?? Other than that im looking at the cheapest option to stay at current power level (346rwkw) and get a good idle. Thoughts?? Link to comment https://www.fordxr6turbo.com/forum/topic/85814-strange-idle-after-engine-swap/page/4/#findComment-1437846 Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 14y 9d Gender: Male Location: Victoria Posted 03/11/13 09:57 AM Share Posted 03/11/13 09:57 AM How much are you going to save buying those over ID1000s?What injector is your tuner advising you to go with? Link to comment https://www.fordxr6turbo.com/forum/topic/85814-strange-idle-after-engine-swap/page/4/#findComment-1437872 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m Posted 03/11/13 10:46 AM Author Share Posted 03/11/13 10:46 AM Man id1000 are over kill for what I want. Tuner likes id750's but I was just interested to know if anyone had used them? They are $300 brand new off a private seller, rrp is $650 I believe Link to comment https://www.fordxr6turbo.com/forum/topic/85814-strange-idle-after-engine-swap/page/4/#findComment-1437899 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 11d Gender: Male Location: Maryborough Qld Posted 03/11/13 11:58 AM Share Posted 03/11/13 11:58 AM my ba xr6t stck besides a cat back exhaust has a really lumpy and missing idle only with aircon off, of air cons on its smooth as!! and instant fuel useage is around 1.3-1.7 (air con off or on)ive replaced everything and its still doimng it haha. im thinking gummed up phasers? would some engin flush help if it was? Link to comment https://www.fordxr6turbo.com/forum/topic/85814-strange-idle-after-engine-swap/page/4/#findComment-1437925 Share on other sites More sharing options...
