  • Member For: 12y 7m 10d
auto or manual mate? your thread probably mentions it....
either way, Has it ever been over revved accidentally? timing issue aside, that's about the only time you'd kiss the valves. The rev limiter can catch an engine on the way up, but if you shift down (kind of like compression braking) the limiter is not capable of catching the revs, due to the wheels driving the engine and not vice versa...
just a thought.
cheers
  • Member For: 22y 3m 18d
  On 02/09/2013 at 7:18 AM, turbotrana said:
The next question is ...... what mods can be done to the engine to prevent the chain skipping teeth.
HD Chain and Tensioner with higher spring presure.
Part of the issue with stock chain is that it is quite weak, and is likely to stretch, especially with stronger springs.
  • 2 weeks later...
  • Member For: 17y 1m 8d
Haven't posted for a while but there really wasn't much happening as the car wasn't here. Ford finally said no after they made me jump through hoops and the car has finally been brought home. I have now reassembled the head with just two valves and timed the cams two teeth in advance and there is no doubt that the valves are hitting when I turned it over but I was still able to push it past I will try to make a vid tomorrow and post it up to see
  • Member For: 14y 5m 23d
Sorry to hijack but the mention of coming off the throttle hard being a potential cause for jumping teeth, is this coming off WOT/higher rpm or applies or just in general? I often accelerate 3/4 and back off when hitting speed limit, and sounds like I really need to stop!
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 14d
I nailed it then hit the brake after I saw a set of lights had a camera in it. Night night for my bf2 engine lol
Here is a link to my demonstration vid of the timing issue
https://www.youtube.com/watch?v=RKbCUTq-ec8
  • Like 2
  • Moderating Team
  • Member For: 22y 2m 11d
What point are you at now?
ie has FoMoCo washed their hands of it, and you are taking it further?
Cool video, very well demonstrated, but I doubt Ford CEO's are surfing youtube right now, and will therefore honour your claim......
