blueprintbullet Donating Members 163 Member For: 17y 3m 3d Gender: Male Location: Wanneroo Posted 27/07/13 10:33 AM Share Posted 27/07/13 10:33 AM Hi Guys Has anyone ever heard of FG's droping valves? Unfortunately today mine did, It is stock as a rock and 9 months out of warranty so I think this is going to hurt. The car has always been driven hard but at the time it went wrong I was driving on the cruise control so I certainly didn't rev it too hard. The only thing I can think of is that about 2 years ago it broke a chain guide and was fixed under warranty, is it possible that it tweaked a valve that long ago and only just let go today? Link to comment https://www.fordxr6turbo.com/forum/topic/85759-fg-droped-a-valve/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 6d Gender: Male Location: Adelaide Posted 27/07/13 10:37 AM Share Posted 27/07/13 10:37 AM Mate its just luck and u got unlucky, its the first ive ever heard of it happening Nothing that long ago would result in it failing today If u have a full service history give ford a crack as u got nothing to loose Link to comment https://www.fordxr6turbo.com/forum/topic/85759-fg-droped-a-valve/#findComment-1410484 Share on other sites More sharing options...
blueprintbullet Donating Members 163 Member For: 17y 3m 3d Gender: Male Location: Wanneroo Posted 27/07/13 10:46 AM Author Share Posted 27/07/13 10:46 AM Don't think I will waste my time, anyone have a complete motor laying around or should I look at going the rebuild. Link to comment https://www.fordxr6turbo.com/forum/topic/85759-fg-droped-a-valve/#findComment-1410494 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 4m 18d Posted 27/07/13 11:10 AM Share Posted 27/07/13 11:10 AM Stock car? Valve float can cause wear on valvetrain that can drop a valve. Link to comment https://www.fordxr6turbo.com/forum/topic/85759-fg-droped-a-valve/#findComment-1410520 Share on other sites More sharing options...
blueprintbullet Donating Members 163 Member For: 17y 3m 3d Gender: Male Location: Wanneroo Posted 27/07/13 11:13 AM Author Share Posted 27/07/13 11:13 AM It didn't drop the collets just let the head go Link to comment https://www.fordxr6turbo.com/forum/topic/85759-fg-droped-a-valve/#findComment-1410526 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 14d Gender: Male Location: Perth Posted 27/07/13 11:32 AM Share Posted 27/07/13 11:32 AM Im with precious. I would go for goodwill from ford. Even if they only cover parts it would be a win. Link to comment https://www.fordxr6turbo.com/forum/topic/85759-fg-droped-a-valve/#findComment-1410528 Share on other sites More sharing options...
BRK Member 361 Member For: 13y 5m 24d Gender: Male Location: Perth Posted 27/07/13 11:39 PM Share Posted 27/07/13 11:39 PM +1 for warranty - heads off valves on a stocker very rare. As for rebuild versus a second hand long - hard to say. It would very much depend on engine damage - dropped valves can damage the head beyond repair and so that would need to be replaced. The short should/might be okay in 5 of the six bores but get the rod crack tested or buy a new one. You might have to rebore as well...... I think you can see where all this is headed bux wiseWanneroo - so WA based. If ford say no - you have Monster torque or XFT as people to deal with and I know West Racing Developments have done quite a few of these engines. Walliston Motor wreckers in Lesmurdie seem to get FG Turbos regularly. The last full engine ( turbo included) I priced from him was $5500.As a suggestion only. If Ford say NO to a warranty claim maybe propose they supply you with a factory long motor at trade price. That will give you an idea as to just how much you will be up for. Link to comment https://www.fordxr6turbo.com/forum/topic/85759-fg-droped-a-valve/#findComment-1410553 Share on other sites More sharing options...
blueprintbullet Donating Members 163 Member For: 17y 3m 3d Gender: Male Location: Wanneroo Posted 29/07/13 09:58 AM Author Share Posted 29/07/13 09:58 AM Had the head off today and found marks on all the pistons! The marks are quite obviously from when the timing jumped 2 years ago as the car has had nothing done except the log book services. So I called ford and told them what had been discovered and they said that the valves couldn't have been bent as they did a compression check. After a heated discussion I ended up down there, which didn't achieve much,. but at least they said they would send the details on to ford and see what they say. I have attached a pic (note it is not the relief cuts on the pistons but the small indents opposite them) Link to comment https://www.fordxr6turbo.com/forum/topic/85759-fg-droped-a-valve/#findComment-1411048 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 10d Gender: Male Location: @ my laptop Posted 29/07/13 10:07 AM Share Posted 29/07/13 10:07 AM a bent valve would have shown straight away as a miss fire and low comp Link to comment https://www.fordxr6turbo.com/forum/topic/85759-fg-droped-a-valve/#findComment-1411054 Share on other sites More sharing options...
welshy_89 Member 131 Member For: 13y 10m 12d Posted 29/07/13 10:09 AM Share Posted 29/07/13 10:09 AM Mate I feel you pain, I had an atomic spring fail about 2 months ago and dropped the valve and then broke the head of the valve off and it bounced around in the bore for a bit and jammed the head of the valve perpindicular in the head, imo I don't think ford will help but as the lads have said the worst they can say is no. The next question u need to ask yourself is how deep are you pockets and are/were you looking to do performance mods on the car and how far you were looking at going, and that will indicate wether to look for a a used long motor or look at rebuilding what you've got Link to comment https://www.fordxr6turbo.com/forum/topic/85759-fg-droped-a-valve/#findComment-1411056 Share on other sites More sharing options...
