  • 6 months later...
  • Member For: 15y 5m 18d
  On 24/05/2014 at 8:23 AM, 04LTRB said:
Just wondering could it be the fuel filter I'm putting a new 1 in it soon so c if that helps at all
I it goes hard in 1st n 2nd its not the fuel filter.
X3 is telling the fault codes, I would be finding a good tuner to diagnose it.
  • 2 weeks later...
  • Member For: 12y 7m
Hey all jus looked in the engine bay , looked at the wastegate hose that goes to the solenoid there was no splits or holes but I noticed the the end that goes into the solenoid was very loose it jus slid on should there be a hose clip or something on it even a cable tie mayb cause this be causing the wastegate to fail / overboosting
  • 1 month later...
  • Member For: 11y 3m 7d
I don't have any on my BA, except for 1 on the wastegate side due to loose hose on Turbosmart actuator. I've got a question regarding a flat spot. My 03 BA has a huge initial flat spot. Whenever I plant the foot, there's a 1.5 - 2 second delay before the desired effect. This occurs from a standing start as well as whilst in motion. I've changed the coil packs and spark plugs and installed a new actuator. I know I should get a tune, but $990 seems a bit steep to just check the air/fuel ratio. One other question, the solid pipe that runs from the turbo to the crossover seems about a cm too short. I've got to have everything just holding on for it to fit. Is there anyway to get a replacement that's a tad longer?
Sent from my GT-I9505 using Tapatalk
  • Member For: 21y 8m 19d
It wont cost you $990 to just get the afr's checked on the dyno. Go see the local guru tuner shop ask them how much it will cost for them to check the engine bay (piping,hoses) and how much for them to run it on the dyno to diagnose and check the afr's if they don't find a problems in the engine bay.
Where are all the Cairns boys???
