  • Member For: 12y 7m 1d
Hey everyone still new to xr6Ts
I picked my car up yesterday after having my turbo changed ( bent impellers)
I had another stock turbo put on
1st an 2nd gear pulled really hard an the when I'm in 3rd get to about 4000rpm it nose dives an theres no power , if I gradually build up the boost it sometimes gets to mayb 5000rpm an stops again
Same thing in 4th gear
Car is an 04 xr6t manual
Any ideas
Cheers Michael
I've been told it may be over boosting what cAn I do to prevent it from happening
I've got an xcal 3 not tuned to my car yet but I can still use it to get fault codes can't I , will that show up with anything
  • Member For: 15y 6m 28d
2 fault codes have come up
P1227 wastegate failed closed ( over pressure )
P1507 idle air control (iac) under speed error
What do I need to do to clear these errors
Any help much appreciated
  • Member For: 18y 11m 26d
it's overboosting, the turbo is not exactly the same as the one removed, possibly just the actuator may be different or you have fitted the hoses incorrectly
