usernumber1234 Member 47 Member For: 12y 9m 29d Posted 29/07/13 11:09 AM Share Posted 29/07/13 11:09 AM I have installed full hid projectors with xenons into bf headlights.hid projectors spread light different to halogen ones. high beam is actually a "cutoff". when you flick the switch a solenoid moves the cutoff down allowing all light out. Link to comment Share on other sites More sharing options...
Kinetic13 Member 4 Member For: 11y 6m 29d Posted 26/08/13 08:56 AM Share Posted 26/08/13 08:56 AM I have put HIDs on my low beams of my mk2 with projector headlamps. Not a hard install, pretty easy compared to the kit I I stalled in my old gti golf which had a H4 lamps with low and high beam in them. The mk2 uses one H7 lamp for the low beam and another H7 for the high beams so danimal would be correct in saying that HIDs shouldn't be used for high beams both for ignition time issues, also longevity of the lamps and longevity of the ballasts. 1 Link to comment Share on other sites More sharing options...
profrat Member 126 Member For: 21y 5m 22d Location: Eastern Victoria Posted 15/01/14 12:28 AM Share Posted 15/01/14 12:28 AM I have installed full hid projectors with xenons into bf headlights.hid projectors spread light different to halogen ones. high beam is actually a "cutoff". when you flick the switch a solenoid moves the cutoff down allowing all light out. From what you say here, do the Projector headlights in BF's produce a different pattern when high beam is switched on? Link to comment Share on other sites More sharing options...
ned New Member 8 Member For: 21y 2m 15d Gender: Male Posted 26/06/14 02:50 AM Share Posted 26/06/14 02:50 AM Anyone had much luck with this? I can't see how the HID globe will be held in place? Link to comment Share on other sites More sharing options...
