  • Member For: 12y 3m 24d
Hi, I have a mk1 2011 xr6 turbo ute.
I'm wondering if the new mk2 xr6 projector headlights would be interchangeable into the mk1, at a glance they seem the same shape but I'm wondering if anyone has done this conversion or knows if its possible without having to change to the mk2 front bumper as I believe the mk1 bumper is much nicer. Thanks..
post-54740-0-75639700-1374656787_thumb.j
post-54740-0-21171300-1374656801_thumb.j
  • Inactive Members
  • Member For: 15y 2m 26d
Hi Ali_g,
I have a g6e turbo & the lights are a direct fit, so I would believe
The xr6 lights would be the same.
All you will need is to modify the wiring on the new lights
& wire in 2 switching relays (1 for each light is easiest), to
Enable the low beam light to remain on when switched to
High beam, as the main lamp is now a h7 single fillament
Bulb instead of a h4 high/low.
Cheers & have fun
Thanks Mirage for your help, where did you purchase your headlights? Just from ford or another source? I'm guessing they arnt cheap, and also the switch relays to suit? Thanks :)
  • Member For: 14y 24d
I paid $220+gst each light. They fit Mk1s no worries. All that needs to be added is the switching relay as mentioned above. Got mine from a auto electrician. Just wired mine up with HIDs. Very happy with the result.
Edited by JET50T
