GeGe6 Donating Members 1,978 Member For: 12y 6m 29d Gender: Male Location: Perth, SOR Posted 23/07/13 01:36 PM Share Posted 23/07/13 01:36 PM (edited) Thought I'd have a crack at installing Led's in my G6ET door handles which also act as puddle lights.Here's a go at a bit of a write up.First you will need to purchase a few things.- 6 x (2 spare) 5mm LED - 4 x resistors (get a few spares as well)- 12m of dual core wire - LED housing (again a couple spare)First I removed the door barrel from driver's side.Open driver door and pop the little black cap that sits at same height as handle.Once this is done, it will expose an Allen key inside. Back Allan key out and it will release door barrel. Unclip the cover from door barrel and cover with masking tape. This will protect it as well as helping with marking out.I measured up 10mm from base that sits against car & 8mm in from edge that sits against handle.I drilled a 7.5mm hole so the chrome LED holder will thread into cover.Repeat for all 4 covers.Next was the door barrel. A dremel will come in handy here.But once modified, it should look like this:I then cut 3x 1m and 1x 1.2m (driver's door) length of wire to run inside each door and soldered the LED to each one.Fit LED to each cover again; a dremel will be handy to create space for wiring.Feed the wire into door and Install handle piece back on car.Next to hook into lights inside, so when you unlock car they come on.The front doors are very easy to connect to the courtesy light in doors.IMPORTANT YOU MUST INSTALL A RESISTOR OR YOU WILL BLOW THE LED.Place resistor between LED and the point where connecting to door light. It will work on either one of the two wires.I forgot on one door and learnt the hard way.The back doors I ran from footwell lights.I ran a wire about 3.5m in length either side.Remove all plastics.Connect to footwell lights.I put resistors in here.Next step to get them into doors.Pull the rubber cover off the connector that sits between the door jam and disconnect connection.I drilled through the centre of both sides of the connector and passed wire through.Once through, get a long cable tie, tape it to the wire and feed through rubber conduit into door.Once wire is into door, if you haven't put a resistor in line, make sure you do before making final connect.LED's cost $2.45each item code ZDO190Resistors 45cents for a pack of 8Item code RRO563wire $1.20 per m WH3057 All purchased from Jaycar electronics.The 5mm Chrome LED bezel holders can be found in hobby shops or on eBay.http://item.mobileweb.ebay.com/viewitem?itemId=120861345847 Edited 23/07/13 01:41 PM by GeGe6 3 Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 6m 29d Gender: Male Location: Perth, SOR Posted 23/07/13 02:04 PM Author Share Posted 23/07/13 02:04 PM Few extra pics. 1 Link to comment Share on other sites More sharing options...
Pixy Angel Expert Donating Members 9,132 Member For: 19y 11m 9d Gender: Male Location: North Jamberoo, NSW Posted 23/07/13 09:13 PM Share Posted 23/07/13 09:13 PM Excellent right up mate you done well.I'll send over my car for you to do............lol. Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 6m 29d Gender: Male Location: Perth, SOR Posted 23/07/13 11:55 PM Author Share Posted 23/07/13 11:55 PM Your on...lol Cheers. Mike Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 5d Gender: Male Location: Adelaide Posted 24/07/13 01:03 AM Share Posted 24/07/13 01:03 AM Top stuff mate ! Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 6m 29d Gender: Male Location: Perth, SOR Posted 25/08/13 10:28 PM Author Share Posted 25/08/13 10:28 PM Found out last night, that the way the puddle lights are wired it allows them to be dimmed.First photo bright, then dimmed down low.http://img.tapatalk.com/d/13/08/26/y9umunyj.jpg[/img 1 Link to comment Share on other sites More sharing options...
Pixy Angel Expert Donating Members 9,132 Member For: 19y 11m 9d Gender: Male Location: North Jamberoo, NSW Posted 26/08/13 05:32 AM Share Posted 26/08/13 05:32 AM Excellent work mate still up to do mine. Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 6m 29d Gender: Male Location: Perth, SOR Posted 26/08/13 12:17 PM Author Share Posted 26/08/13 12:17 PM Send it over to me after you get the new brakes. Can't promise it returning with them still on. 1 Link to comment Share on other sites More sharing options...
beastrado Member 23 Member For: 11y 11m 24d Posted 04/09/13 10:55 PM Share Posted 04/09/13 10:55 PM Looks good mate Link to comment Share on other sites More sharing options...
Hype Member 77 Member For: 11y 5m 3d Gender: Male Location: Canberra Posted 05/09/13 12:02 AM Share Posted 05/09/13 12:02 AM Excellent write up! Link to comment Share on other sites More sharing options...
