  • Member For: 14y 8m 13d
I had my T tuned earlier this year & got a bolt-on CAT fitted at the same time. After a couple weeks it sounded like there was a 'muffle' sound from inside the engine bay,so I took the heat shields off to inspect further & a definate leak seems to be coming at the point of connection between the cat & dump pipe.
My question is what affect does this have on my car if any?(performance wise & any detrimental affects leaving it like this).
Depending on answers above if this leak was present during the dyno tune would it mean a re-tune may be needed when the leak is fixed?
https://www.fordxr6turbo.com/forum/topic/85691-exhaust-leak-on-ba-t/
  • Bronze Donating Members
  • Member For: 12y 2m 4d
Depending on how bad the leak. If it is bad, then you may loose a little throttle response when not on boost and between idle and 1700rpm. I would also think your tuner would hear any leaks as they listen to cars every day and there ears are fine tuned to any problem sounds.
No need for a retune if it is a leak after the turbo(unless there is a hole in your dump pipe of course, then you may run a little rich when coming on boost once repaired).
My 2 cents anyway.
Edited by AdamIan69
Hi AdamIan69,
Thanks for the reply....Car does seem bit uninspiring down low(just like when it was stock), hoping this is the reason. Tuner said I had a sus wastegate hence why bit sluggish.
Not sure Tuner noticed it or whether it was there initially but I can even notice from inside the cabin.
