Dash Board Lights Flickering
xr6glory
  • Member For: 12y 3m 29d
Hey guys
Only recently my 2006 BF xr6 has had flickering within the dash board when driving at night.
Once Ive turned my lights on, whenever I indicate left or right or turn my high beams on, my whole dash board and all middle compartment and lights all switch off back to day time driving and once ive turned the corner, they switch back to night.
Im assuming that the fuse has blown within the electrics but a second oppinion would be helpful
cheers
  • Cruise Control
  • Member For: 18y 7d
Check to see if its only the dashlights or the parklights that are going on and off?....
My guess would be a broken wire in your combination switch......common problem that you can fix with a bit of wire and a soldering iron.
Beats paying 300+ dollars for a new switch too....
Take off the covers around the steering column and the back of the indicator stalk and you may see a broken wire or two....
