  • Bronze Donating Members
  • Member For: 14y 1m
  On 10/07/2013 at 1:07 AM, AdamIan69 said:
If you use too much coolant your engine won't cool as well as running the right mixture. Nothing cools better then straight water, and coolant is not very good at transferring heat. If your using premix I wouldn't worry about it.
WHS
It's all about getting the right consistency. It's designed to stop water corrosion within the engine / radiator and boiling in extreme conditions but doesn't work as well as water from a cooling/flow POV as it is a thicker fluid.
Edited by _Velocity_
  • Member For: 12y 1m 3d
Well done velocity. We wouldn't want a reader to go fill his car with water after reading my last thread.
