AdamIan69 Bronze Donating Members 401 Member For: 11y 11m 25d Gender: Male Location: WA Posted 08/07/13 09:10 AM Share Posted 08/07/13 09:10 AM Exactly what you described. Link to comment https://www.fordxr6turbo.com/forum/topic/85531-car-shutting-down-while-driving/page/2/#findComment-1405040 Share on other sites More sharing options...
-LYNCHO- Member 16 Member For: 12y 1m 14d Gender: Male Location: Perth Posted 12/07/13 02:42 AM Author Share Posted 12/07/13 02:42 AM (edited) So scanner came up with zero faults. Auto sparky was stumped. Didn't check ecu plugs because we couldn't get it off as it is riveted on. Anyone know how to remove these? Also determined that it is getting fuel, however just got getting spark. This is leading me more towards CAS again. I think my next step will be to put the bloody thing on a tow truck and take it back to Simon at XFT. If anyone is going to know it will be him.Edit: would the scanner have connected to the ECU if the problem was the plug? Edited 12/07/13 02:43 AM by -LYNCHO- Link to comment https://www.fordxr6turbo.com/forum/topic/85531-car-shutting-down-while-driving/page/2/#findComment-1406016 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 24d Gender: Male Location: Perth Posted 12/07/13 03:02 AM Share Posted 12/07/13 03:02 AM Seriosuly doubt its the CAS. They are a very simple sensor that will either work or it won't. Do you have a coolant leak by anychance? Coolant has been known to leak from the thermostat housing and drip into the CAS plug and cause issues.You can remove the PCM plugs without removing the PCM. There are access holes in the mount that allow you to pop the retainers back and remove the plugs.To remove the PCM shear bolts you need to cut a groove in them with either a hack saw or dremel then use a large flat bladed screw driver to remove. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85531-car-shutting-down-while-driving/page/2/#findComment-1406028 Share on other sites More sharing options...
matsfgxr6turbo Member 388 Member For: 15y 2m 10d Posted 12/07/13 09:58 AM Share Posted 12/07/13 09:58 AM its trying to save you fuel just like those commodores that shut down then start back up Link to comment https://www.fordxr6turbo.com/forum/topic/85531-car-shutting-down-while-driving/page/2/#findComment-1406154 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 8m 10d Gender: Male Location: Melbourne Posted 12/07/13 11:27 AM Share Posted 12/07/13 11:27 AM When I had a brand new BF T - engine cut out once whilst driving on SE Freeway. Ford replaced my electronic throttle control unit. Didn't cut out again for rest of 2 year lease. Not sure if that's another lead to follow up on Link to comment https://www.fordxr6turbo.com/forum/topic/85531-car-shutting-down-while-driving/page/2/#findComment-1406203 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 11y 11m 25d Gender: Male Location: WA Posted 12/07/13 11:50 AM Share Posted 12/07/13 11:50 AM I think my next step will be to put the bloody thing on a tow truck and take it back to Simon at XFT. If anyone is going to know it will be him." True, however it will hard for any mechanic to fix due to irregularity of the fault. You could try a harness wiggle test and see if it shuts down. Start it and wiggle all plugs and all of the harness. Link to comment https://www.fordxr6turbo.com/forum/topic/85531-car-shutting-down-while-driving/page/2/#findComment-1406209 Share on other sites More sharing options...
-LYNCHO- Member 16 Member For: 12y 1m 14d Gender: Male Location: Perth Posted 14/07/13 03:23 AM Author Share Posted 14/07/13 03:23 AM On 12/07/2013 at 11:50 AM, AdamIan69 said: I think my next step will be to put the bloody thing on a tow truck and take it back to Simon at XFT. If anyone is going to know it will be him."True, however it will hard for any mechanic to fix due to irregularity of the fault. You could try a harness wiggle test and see if it shuts down. Start it and wiggle all plugs and all of the harness.I wish I could, but it's not starting at all. Definitely no leaks, and nothing from thermostat housing. Those sheer bolts are a real bitch. What was the advantage of them over real bolts anyway? If it was the ecu though, would the scanner have connected to it in the first place?I will give XFT a call tomorrow and see what they think, and let y'all know. Thanks for help guys, much appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/85531-car-shutting-down-while-driving/page/2/#findComment-1406596 Share on other sites More sharing options...
-LYNCHO- Member 16 Member For: 12y 1m 14d Gender: Male Location: Perth Posted 20/08/13 12:45 AM Author Share Posted 20/08/13 12:45 AM So finally some news back from XFT. They have narrowed it down to a short along the ignition line. They have been through about 50 fuses trying to find it but havent as of yet. that's a releif for me as its not the ecu or something more costly. They said they should have it sorted by early next week (Simon has been out crook and only just back at work). 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85531-car-shutting-down-while-driving/page/2/#findComment-1417299 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 11y 11m 25d Gender: Male Location: WA Posted 23/08/13 11:15 AM Share Posted 23/08/13 11:15 AM Good to hear mate! Link to comment https://www.fordxr6turbo.com/forum/topic/85531-car-shutting-down-while-driving/page/2/#findComment-1418277 Share on other sites More sharing options...
