garyk New Member 2 Member For: 11y 4m 28d Gender: Male Posted 24/06/13 05:54 AM Share Posted 24/06/13 05:54 AM Hi All,I have an issue with my 2009 FG G6E Turbo that started this weekend, was wondering if anyone else has come accross it.The left turn signal is constantly on when the car is running (or off but ignition in accessory positon).You can still indicate right however when the selector returns to the middle/neutral the left signal starts again.Another indicator stalk was tested on my car and the same issue was occuring.Other things that have been tried:- remove the turn signal fuse, the left turn signal is still on.- remove the turn and hazard fuse, the left turn signal is still on.- unplug the whole steering cluster under the steering colum, the left signal is still on.- unplug some more looms on the passenger side, rear turn signal turns off but mirror and headlight turn signal are still on.My mechanic has called a few Ford services centres and none of them know of this issue.Suggestions welcome.Gary. Link to comment Share on other sites More sharing options...
Pixy Angel Expert Donating Members 9,132 Member For: 19y 8m 25d Gender: Male Location: North Jamberoo, NSW Posted 24/06/13 06:59 AM Share Posted 24/06/13 06:59 AM Well firstly mate. great car you had it long? What colour? Any mods done?Try replacing the globe. I would say the globe is one its way out but saying that I could be way off. Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 10m 3d Gender: Male Location: Christchurch, New Zealand Posted 24/06/13 08:12 AM Share Posted 24/06/13 08:12 AM Do you have a trailer plug? If so is it possibly short wiring from there back through the system? Link to comment Share on other sites More sharing options...
BennoG6ETURBO Donating Members 23 Member For: 12y 6m 9d Gender: Male Location: Canberra Posted 24/06/13 09:33 AM Share Posted 24/06/13 09:33 AM With the fuse pulled and it still running, makes me think you have a "foreign battery" fault (meaning the indicator circuit is getting power from somewhere it shouldn't).Like Wenier said, a good place to start would be trailer plug or other electrical mods...A good auto elec should sort you out in no time. Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 3m 25d Gender: Male Posted 24/06/13 10:07 AM Share Posted 24/06/13 10:07 AM Trailer plug Link to comment Share on other sites More sharing options...
garyk New Member 2 Member For: 11y 4m 28d Gender: Male Posted 25/06/13 02:26 AM Author Share Posted 25/06/13 02:26 AM Hi All,Turns out it was the instrument cluster/speedo causing the indicator issue, glad that ones been solved!All your responses were spot on though these are things the Mechanic and Autoelec had ruled out.I've had the car for 7 months now, It's an ex company car that was kept very clean, picked it up with 79k on the clock, Ego with black interior and factory 18" wheels.Only mods so far are some lowered springs and tint. No plans for tuning yet but I wont rule it out.Overall very happy with the car.Thanks for your replies.Gary Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 11m 27d Gender: Male Location: Probably above atmospheric pressure Posted 25/06/13 05:32 AM Share Posted 25/06/13 05:32 AM I fear the day my car starts to get eletrical gremlins. Did it require a whole new cluster? Link to comment Share on other sites More sharing options...
