  • Member For: 12y 27d
Hopefully wed 9th July, the gearbox should have worn in by then. Will post WSID results, however it drives like a tight car even
with lower ''Dyno figures''. It drives linear and shifts hard but forward, if that makes sense. Not all or nothing!
MJS
Cheers Joe@CMS
  • Member For: 17y 29d
try doing your burnouts in manual shift (better throttle and revs control. hold it at 5800- 6000rpm then shift 2nd as you lift off brake shift 3rd.) seems to work with mine.
first time after retune I did the burnout in "D" for drag I hit the limiter too hard and went into limp mode with lotsa squeal and no smoke lol.
when you launch try and feed the power until you can work out the sweet spot (bit like a manual)
I've been working on this for over 90 passes now (still finding more things to tweak as I go but hey that's the challenge) with seat time it will get easier.
now who says drag racing is just driving fast in a straight line? lol
good luck with it and keep us updated on how you go.
