  • Member For: 12y 21d
Ok good call nice run,
Was that 11.2 on quality street tyres and wheelspin that bent you out of shape or spun straight, either way you would have to have lost traction with 450 odd kw.
spin in 2-3-4?
First run. Trans went into limp mode
Second run. 1/3 down track boost kicks I on Hankook venis street tyres car all over the shop
recover. 13.8@116.23mph
Third run. TRACTION ON spun half track 12.6@118.26.
I need ET Radials or similar.
Look up your Moroso calculator and see what that trap speed is equivalent to.
  • Bored Member
  • Administrator
  • Member For: 22y 6m 26d
  On 23/06/2013 at 3:03 AM, Ford Freak said:
Where did my post go?
Dags cleaned up the Bill & Bob show send a pm to somebody who cares.
First post update....
  • Moderating Team
  • Member For: 22y 4m 9d
  On 23/06/2013 at 5:46 AM, stevanford said:
450rwkw and only 118mph down the 1/4 ?
well thread title says 454
dyno sheet saty 454
op then says 470
anybody can throw a fistful of coin at these cars and get a sexy dyno sheet, its another thing altogether to get it to run quick down the strip.
  • Member For: 17y 29d
If your serious about the track mts are a good starting point, with 450 would expect around 135/138 mph with a healthy box, the time will be up to whether you can pedal a damn.
  • RNS10S
  • Member For: 18y 9m 24d
spin in 2-3-4?
Nitto Invos 275/30/19, 400rwkw
true track diff centre so it spins nice and straight, wheelspun on 1-2 and 2-3 change but MPH was true to the power at 131.7
  • Like 4
It is a very good point about power and 1/4 Mph.( don't always mate)
I ran three passes last wed the first run I did a long crowd pleasing burnout
to put heat in my 245/40/18 Hankooks. When the tree dropped I gave it WOT and
the ECU placed the ZF in limp mode.
This is where someone with knowledge can help me, as I crawled along I passed 330f at 8.84sec then shortly after that,the ECU gives my gearbox back and I went on to pass at 17.3@106.23mph.
Does this help 'prove' my power?
P.s Has this happened to anyone else?
Scan0005.pdf
