Wat1/4 Time Can I Expect With A 10Psi Flash Tune And K&n Pod
twisty88
  • Member For: 16y 18d
Twisty, it's called constructive criticism.
But in all seriousness get yourself a custom tune. And look after your engine.
Edited by southside
  • Member For: 12y 8m 17d
Wouldn't it be a good idea just to go to a good tuner and get them to do a power run on the dyno to check A/F and boost pressure.
If it is ok, no stress, and if it needs adjusting book it in for full tune to get it sorted.
Probably only cost $100 for power run to check it
  • Member For: 14y 3m 10d
Twisty, welcome to the forum, and all the BS that goes with it. If this is your 1st forum, you will need to loosen up real bad, or you will sink. Most on here dont know jack, but like to stir the pot.
A sump full of oil on the drag strip(or road in my case :tear2: ) makes a big mess. Try and avoid it.
