980Cc @ 4 Bar Unmolested Injector
  • Member For: 19y 7m 13d
Being a 30 degree cone can you stick it in a head and suss out if the two grooves that lead into each port get 'wetted' down at all. Would be good to assess against the narrow cone models. Also your 550cc, I gather they are the six hole std injector 0280158117 (but obviously well matched which is great), have you stuck them in a head also as they have a 12 degree offset spray and they need to be installed the correct way.
  • Member For: 21y 10m 22d
When you do that data can you also characterize it for 4.5 Bar. I run a hi flow 4.5 bar regulator (thanks again Toads). Rather than molest the injector for the flow you are better off selling customers a hi-flow reg at 4.5 or 5 bar. If these injectors work out then you have a sale from me. It would also be a time for a group buy.
  • Member For: 19y 3m 30d
We are currantly testing suiatbilty and fitmant into various engines / runner designs. We will realses findings as we proceed.
