  • Member For: 22y 30d
  • Member For: 12y 7m 28d
Set of 4 for $450usd, add two more 1/2 of 450 = 225 (- a bit for combined shipping)
So it's nearly at the $660 mark which most tuners here sell ID1000's for.
I hunted high and low for injectors before I got mine. Looked at all EFI sites, through the uk, USA (five-0 included), I ended up scoring a set. My .02c, just spend the $660ish locally, it could save some time and headaches... From what I learnt.
If you are into injectors and got a bit of time on your hands check out this thread.
Some heated discussion between Tony from Injector Dynamics and another injector supplier,TSM.
http://www.gtrlife.com/forums/topic/78932-tsm-pro1050-injector-bench-test-video/
  • 2 weeks later...
  • Member For: 13y 2m 6d
I had a bad experience with ev14s. End of the day you get what you pay for with injectors. Am now left with a set of bosch injectors I have no use for. Stick with IDs and you wont have any problems.
  • Waiting for the 1st N/A 12!
  • Member For: 17y 2m 18d
Ive been using fiveo's for almost 2 years now. Amazing injectors but come with no calibration summary so your tuner needs to put some serious work in to get them right.
Just put a set of their 1600's in this week.
Sent from my GT-I9505 using Tapatalk 2
  • Member For: 19y 9m 21d
Ive been contacted by a few different people regarding injector issues and its been a result of modified injectors (seen a few EV-14's 'dodgy drilled') and/or poor tuning because the injector is new to the tuner and they either haven't bothered or don't know how to adjust the scaling OEM style.
Edit: given the design of the EV-14 Trana mentioned it would be interesting to see how close the director plate is to the bridge separating the inlet ports to the two valves.
Edited by IH8TOADS
I have since found that the above injector does come with standard nozzle (cant remember exactly where I saw it). I would expect someone to formulate the injector data for this injector in the not to distant future.
But the funny thing was that the coy that was selling the injector (the one with the standard nozle) was drilling just one hole to get the flow above 1000cc which I found so stupid. Better just to raise the fuel pressure a little.
It's the Bosch injector sheet. Shows the body type and sure enough it does come in the stumpy version! Drilling one hole to make it 'unique' is retarded!
  • Member For: 19y 6m 7d
KPM are in the process of charecterisizing and assesing this same injector.
