  • Member For: 12y 9m 19d
Hey guys..
Started a couple weeks ago, If I put my foot down in any gear and boost it, I.e. from the lights in first gear to 4000rpm, then back off or change to second and keep going, either way soon as I back off, the engine shudders and revs fluctuate quite a bit, the engine almost stalls
> I've cleaned out throttle body
> air intakes
> plugs are still good
> always run 98
> let the engine warm up before pushing it
> my mechanic gave the car a look over after changing the rear diff bush and said car looks good
Any ideas?
Anyone have experienced similar issues?
Cheers
Thanks for the quick reply man... I was really hoping it wasn't valve springs.. anything else it could be or are the symptoms a trademark for worked out or over sprung valve springs?
  • Member For: 18y 8m 20d
13psi tune from the X3 flash unit
Monza cooler
K&N filter
APS Phase 1 (the ecu only I think)
T5 with worn out clutch lol
Flutter BOV
130000kms on clock, very clean engine and no smoke etc
All the mods were done by previous owner
shouldn't the stock valve springs still be ok? what's their max rwKW? or is my beast pumping out too many rwKW?
  • Member For: 16y 6m 26d
Valve springs are like shock absorbers, they wear out after a while and go soft.
Still only assuming it's the valve springs though.
