jas98 Member 1,046 Member For: 12y 9m 14d Gender: Male Location: Maryborough Qld Posted 14/06/13 05:24 AM Share Posted 14/06/13 05:24 AM OK, story goes I checked codes 2 weeks ago and came up with power steeringswitch which has been replaced but codes still there(another story lol)I replaced engin mount under turbo so had to remove turbo. all good, cars going great.then the other day I checked codes again and it came up with P1131....and now today its also got P1132.it seems to be missing slightly at idle. also since this code it does not surge when cold anymore wtf! lolany thorghts? I know the intercooler pipe under turbo has a slight spit in it but I put a hose clamp over it and its still boosting to 6psi easy.I also have a sh*t load other codes but there not for the PCM Link to comment https://www.fordxr6turbo.com/forum/topic/85286-code-p1131-and-p1132/ Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 10d Gender: Male Location: @ my laptop Posted 14/06/13 06:38 AM Share Posted 14/06/13 06:38 AM 2 3 things in life are a certainty,death, taxes and jas98 posting about more issues 3 Link to comment https://www.fordxr6turbo.com/forum/topic/85286-code-p1131-and-p1132/#findComment-1398207 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 14d Gender: Male Location: Maryborough Qld Posted 14/06/13 02:55 PM Author Share Posted 14/06/13 02:55 PM lol 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85286-code-p1131-and-p1132/#findComment-1398373 Share on other sites More sharing options...
f-wolf Member 897 Member For: 18y 12d Gender: Male Location: ACT Posted 15/06/13 03:05 AM Share Posted 15/06/13 03:05 AM Found this: DTC P1131 indicates the system is correcting RICH for an overly LEAN condition. The Heated Oxygen Sensor (HO2S) voltage is less than 0.45 volts. This is usually due to a vacuum leak after the MAF. It can also be caused by a bad PCV valve or PCV system hose.It can also be caused by low fuel pressure or a plugged injector.P1132 FORD DescriptionA Heated Exhaust Oxygen (HO2S) sensor indicating rich at the end of a test is trying to correct for an over-lean condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85286-code-p1131-and-p1132/#findComment-1398460 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 14d Gender: Male Location: Maryborough Qld Posted 15/06/13 08:18 AM Author Share Posted 15/06/13 08:18 AM changed o2 sensor and reset computer, seesm to be working and cars going great......yet another o2 sensor faulty...my car just loves them haha Link to comment https://www.fordxr6turbo.com/forum/topic/85286-code-p1131-and-p1132/#findComment-1398550 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 14d Gender: Male Location: Maryborough Qld Posted 15/06/13 08:24 AM Author Share Posted 15/06/13 08:24 AM (edited) oh and also changed the power steering switch...still has code but was told they always show that code? only shows the power steering fault code when doing the key on engin off test. seeing I changed both the o2 sensor and power steering sensor at same time im not sure which one has made it idle smoother....also power steering seems smoother??there is no codes in PCM now only codes I have is for the:rear dimisterblower fan2 for wipershowever they all work fine..so im not to worried bout itall others I have fixed lol Edited 15/06/13 08:26 AM by jas98 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85286-code-p1131-and-p1132/#findComment-1398552 Share on other sites More sharing options...
