  • Member For: 12y 10m 7d
  On 20/06/2013 at 1:58 AM, ratter said:
the fuel is putting a band aid on your problem
Agree..
can a blcoked fuel filter and/or bad fuel pump be the problem?
also are you sure its pinging? not some other noise?
Edited by jas98
  • Member For: 20y 12d
Yeah I'm quite sure as I know that pinging noise...
Yeah I was thinking about changing the fuel filter...I might change it over the weekend.
Could a clogged up catalytic convertor also be a cause of pinging?
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 29d
Cat not so much but fuel system would be first port of call for a looksee
  • Member For: 16y 10m 12d
I have the same problem - should the knock sensor be picking it up and retarding the ignition? Also, why are no trouble codes being registered?
  • Member For: 19y 3d
it possibly might be picking it up but the required retatrd exceeds what is programmed into the ecu I.e it is needs 10 degrees removed but the sensor is programmed to remove 8, so the car will still ping
  • Member For: 18y 1m 5d
  On 21/06/2013 at 11:54 AM, boost69 said:
...if the cat is getting clogged up, would the o2 sensors pick something up and force a code?
*** Yes... it will set a code... And will in some cases go in to Limp Mode.
A Friend's Ute had a stuffed Cat-Converter.
Ford Dealer told Him... nothing wrong... LOL
Edited by f-wolf
