f-wolf Member 897 Member For: 18y 13d Gender: Male Location: ACT Posted 08/06/13 04:02 AM Share Posted 08/06/13 04:02 AM (edited) JordyGI send you a Message. See how you go with it. Let us know if it works.Reset the cam phasers1). Turn ignition to ON2). Hold foot all the way to floor on accelerator.3). Turn key as if to start.4). Dont worry car wont start as sensor on accelerator knows you are flooring it.5). Hold key like this and count to ten. During this time the starter motor will be going - dont worry this is normal6). Turn key back to OFF.7). Take foot off accelerator. . Wait 30 seconds then start as normalThis resets the cam phasers...Variable Cam Timing SystemThe Barra I6 engines are fitted with dual equal variable cam timing system. There is one Variable Cam Timing Actuator per camshaft; the cam timing is variable between -10° and 50° of crankshaft rotation.Modes of OperationStart Up / Idle Mode:At start up and during idle, the Actuators (phasers) are locked in the fully advanced position. A hydraulic locking pin within the Actuators will lock the camshafts manually.(Duty Cycle is 0%)When the throttle is opened and engine speed exceeds 1000 RPM, Drive Mode is initiatedDrive Mode:The Drive Mode starts at different RPM points, dependant upon Engine Oil Temperature. The PCM actuates the Variable Cam Timing Solenoids through a 20% to 80% duty cycle. This allows oil under pressure to operate the Variable Cam Timing Actuators.The PCM monitors the Camshaft Position Sensors for actual cam timing (closed loop), it will adjust the duty cycle to the Solenoids individually to achieve the desired cam timing.Shut Down Mode:When the engine is shut down, the Actuators return to the fully advanced position, a hydraulic locking pin within the Actuators lock the camshafts manually.Failure Mode:Should any of the sensors required for variable cam timing operation fail, Failure Mode is initiated.The duty cycle of the Solenoids is set at 0%.The hydraulic locking pin within the Actuators will lock the camshafts into the fully advanced position.Variable Cam Timing ActuatorsThe Variable Cam Timing Actuators (phasers) are incorporate into the camshaft drive sprockets; they should not be dis-assembled from the camshaft sprockets as they are serviced as an assembly. They are operated by the Variable Cam Timing SolenoidsThere are 5 holes on the rear face of the Variable Cam Timing Actuators, one is for the locating dowel and the other four are for advance oil supply. The retard oil supply is through the centre of the unit Edited 14/06/13 10:10 AM by Dagabond Link to comment https://www.fordxr6turbo.com/forum/topic/85211-engine-frustration-help/page/3/#findComment-1396671 Share on other sites More sharing options...
dustyae86 Member 46 Member For: 13y 7m 2d Posted 09/06/13 07:27 AM Share Posted 09/06/13 07:27 AM NO NO NO!!! did this happen to do it after it saw a bit of boost and you jumped off the throttle?My car is one of the cars that mick is talking about, it jumped 2 teeth on the timing chain and sounded the same, but my phasers were also bottoming out making it sound scary.get it fixed as soon as you can.Expect close to a grand to fix if it's not done any damage. Link to comment https://www.fordxr6turbo.com/forum/topic/85211-engine-frustration-help/page/3/#findComment-1396878 Share on other sites More sharing options...
JordyG Member 9 Member For: 12y 1m 16d Posted 09/06/13 10:13 AM Author Share Posted 09/06/13 10:13 AM Yep not long after giving it a squirt.But its definitely not making any scary sounds.. hopfully no damage is done.It sounds exactly like it has gone into failure mode.So it looks like il be up for a cam timing sensor. Link to comment https://www.fordxr6turbo.com/forum/topic/85211-engine-frustration-help/page/3/#findComment-1396898 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 11d Gender: Male Location: @ my laptop Posted 09/06/13 11:25 AM Share Posted 09/06/13 11:25 AM no, do not replace that sensor with out testing it, they are not normally an issue. Link to comment https://www.fordxr6turbo.com/forum/topic/85211-engine-frustration-help/page/3/#findComment-1396921 Share on other sites More sharing options...
JordyG Member 9 Member For: 12y 1m 16d Posted 09/06/13 11:49 AM Author Share Posted 09/06/13 11:49 AM (edited) No I sure wont be doing anything myself. It will be going back into another shop Tuesday. The guy that runs this one apparently knows his stuff. So looking forward to some light being shed Edited 09/06/13 11:55 AM by JordyG Link to comment https://www.fordxr6turbo.com/forum/topic/85211-engine-frustration-help/page/3/#findComment-1396928 Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 4m Gender: Male Location: In my house Posted 09/06/13 10:41 PM Share Posted 09/06/13 10:41 PM keep us informed mate and hope all is fixed. Link to comment https://www.fordxr6turbo.com/forum/topic/85211-engine-frustration-help/page/3/#findComment-1396978 Share on other sites More sharing options...
MikeT36 Member 77 Member For: 12y 1m 26d Gender: Male Location: Perth Posted 10/06/13 07:22 AM Share Posted 10/06/13 07:22 AM On 08/06/2013 at 5:28 AM, f-wolf said: Variable Cam Timing SystemThe Barra I6 engines are fitted with dual equal variable cam timing system. There is one Variable Cam Timing Actuator per camshaft; the cam timing is variable between -10° and 50° of crankshaft rotation.50° of Advance timing?? that's insane Link to comment https://www.fordxr6turbo.com/forum/topic/85211-engine-frustration-help/page/3/#findComment-1397048 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 15d Gender: Male Location: Perth Posted 10/06/13 07:43 AM Share Posted 10/06/13 07:43 AM 50deg of crankshaft rotation so only 25deg of cam advance Link to comment https://www.fordxr6turbo.com/forum/topic/85211-engine-frustration-help/page/3/#findComment-1397053 Share on other sites More sharing options...
MikeT36 Member 77 Member For: 12y 1m 26d Gender: Male Location: Perth Posted 10/06/13 08:04 AM Share Posted 10/06/13 08:04 AM oh with you now sounds more reasonable I though 50°was to good to be true yet alone usable Link to comment https://www.fordxr6turbo.com/forum/topic/85211-engine-frustration-help/page/3/#findComment-1397057 Share on other sites More sharing options...
dustyae86 Member 46 Member For: 13y 7m 2d Posted 10/06/13 10:32 AM Share Posted 10/06/13 10:32 AM will bet money that it has jumped a tooth or two Link to comment https://www.fordxr6turbo.com/forum/topic/85211-engine-frustration-help/page/3/#findComment-1397109 Share on other sites More sharing options...
