FAST-XR EVIL T Member 259 Member For: 16y 5m 18d Gender: Male Location: Liverpool NSW Posted 06/06/13 05:13 AM Share Posted 06/06/13 05:13 AM in the last couple of weeks shifing has become very notchy and very hard to get into reverse.Currently running mal wood option3 plus, installed about 45,000 kms ago, car has done 100,000 kmsmy first point of call will be gearbox oil change, followed by clutch fluid changeis castrol transmax z is still the prefered oil of choice these days?anything else I should take a look at while im at it?thanks Link to comment https://www.fordxr6turbo.com/forum/topic/85200-notchy-shifting-in-bf-t56/ Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m 6d Gender: Male Location: Sydney Posted 06/06/13 06:11 AM Share Posted 06/06/13 06:11 AM mines a bit the same tbh though comes good once the box is warmed up Link to comment https://www.fordxr6turbo.com/forum/topic/85200-notchy-shifting-in-bf-t56/#findComment-1396168 Share on other sites More sharing options...
MikeT36 Member 77 Member For: 12y 2m 15d Gender: Male Location: Perth Posted 06/06/13 06:33 AM Share Posted 06/06/13 06:33 AM On 06/06/2013 at 6:11 AM, Kroozin said: mines a bit the same tbh though comes good once the box is warmed up+1 Link to comment https://www.fordxr6turbo.com/forum/topic/85200-notchy-shifting-in-bf-t56/#findComment-1396181 Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 5m 18d Gender: Male Location: Liverpool NSW Posted 06/06/13 10:29 PM Author Share Posted 06/06/13 10:29 PM had issues getting into reverse this morning, took me at least 10 atempts to get it in. I just couldnt get it in the gate.also noticing that the pedal travel has deteriated and seams to be engaging just off the floor, I think its been gradual and only I noticed it now becuase of the issues.does this seem fluid and temp related? or mechanical issue? Link to comment https://www.fordxr6turbo.com/forum/topic/85200-notchy-shifting-in-bf-t56/#findComment-1396336 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m 6d Gender: Male Location: Sydney Posted 07/06/13 12:06 AM Share Posted 07/06/13 12:06 AM I would say give it a quick bleed but that's a *beep* of a job without the hose extension. Do you know if it has the bleeder hose? Usually comes with the clutch u bought. Has it been using clutch fluid or is it black and full of gunk in the little reservoir? Link to comment https://www.fordxr6turbo.com/forum/topic/85200-notchy-shifting-in-bf-t56/#findComment-1396348 Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 5m 18d Gender: Male Location: Liverpool NSW Posted 07/06/13 12:13 AM Author Share Posted 07/06/13 12:13 AM yeah I spent the little extra and got the braided bleed kit, have not checked the fluid yet, will give me something to do this weekend! Link to comment https://www.fordxr6turbo.com/forum/topic/85200-notchy-shifting-in-bf-t56/#findComment-1396353 Share on other sites More sharing options...
BRK Member 361 Member For: 13y 5m 14d Gender: Male Location: Perth Posted 07/06/13 12:20 AM Share Posted 07/06/13 12:20 AM Just off the floor - might be mech issue - Any fluid loss in the clutch fluid reservoir? If yes, have a look at the master cylinder for any leaks. (they aren't cheap if they ares tuffed) Then go underneath and pull out the little inspection panel at the front of the bellhousing and see if there is any fluid in there.If you don't want to bleed the system, you MIGHT get away with pumping the pedal about 30-40 times and hoping that any air bubbles might go into the fluid reservoir. This used to work occasionally in the old skool systems..A 100 opinions on gear oils. But dex 3 or transmax z seems to be ok. Dex 3 is budget.. Link to comment https://www.fordxr6turbo.com/forum/topic/85200-notchy-shifting-in-bf-t56/#findComment-1396356 Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 5m 18d Gender: Male Location: Liverpool NSW Posted 07/06/13 12:32 AM Author Share Posted 07/06/13 12:32 AM just checked my clutch fluid.... empty!have not seen any fluid on the floor, none under the dash, will check bell housing and hose connections when I get home. Link to comment https://www.fordxr6turbo.com/forum/topic/85200-notchy-shifting-in-bf-t56/#findComment-1396359 Share on other sites More sharing options...
DD-XR-6T Member 134 Member For: 12y 2m 1d Gender: Male Location: Sydney/Canberra Posted 07/06/13 12:43 AM Share Posted 07/06/13 12:43 AM Is it like your brakes? When the clutch wears down the fluid goes down with it? Link to comment https://www.fordxr6turbo.com/forum/topic/85200-notchy-shifting-in-bf-t56/#findComment-1396361 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m 6d Gender: Male Location: Sydney Posted 07/06/13 03:43 AM Share Posted 07/06/13 03:43 AM I had to replace my clutch slave cyl. not so long ago. New ones aren't too dear from mw just a pita to swap out. Def try the fluid 1st may have to top it up a few times but if the problem sticks more than likely your csc is weeping Link to comment https://www.fordxr6turbo.com/forum/topic/85200-notchy-shifting-in-bf-t56/#findComment-1396382 Share on other sites More sharing options...
