  • Member For: 18y 10m 17d
Got a new PB last nite 10.01@139.8 before I broke the stock gearset in the powerglide!
Was run on 17" m&h radials 1.55 60ft
Lee
  • Like 5
  • 2 weeks later...
  • Toughest BA Turbo
  • Member For: 22y 3m 19d
Good result. At 24lb you're barely pushing that turbo, as 30lb + to get the best out of it. It is rated at 900hp.
What is the spool like? That Precision is supposed to spool really good.
Brian
  • Like 2
Thanks Brian,yes it got plenty more in it boost wise ,it spools as quick as the factory turbo.
I highly rate their turbos,it's exceeded my expectations
Lee
Edited by dalts
  • Toughest BA Turbo
That's good.
If you want to chase a bit more up top the 6766 with bigger compressor is another option, although some loss of spool.
Indicative http://forums.evolutionm.net/evo-engine-turbo-drivetrain/605026-new-cea-precision-6466-dyno-graphs-vs-6266-6766-inside.html
6466 does look good in comparison. Plenty of options available.
Brian
They are some impressive numbers from those 3 turbos considering the size of them!
It's shows that there are plenty of turbos out there to make big hp without going to a big frame turbo.
Lee
