Danxr Member 67 Member For: 16y 7m 13d Gender: Male Location: Perth WA Duncraig / Wanneroo Posted 27/05/13 01:40 PM Share Posted 27/05/13 01:40 PM Anyway I know you guys hate me already butCar: 2007 BF series 2 Falcon xr6 turboColor: White - Because that helps how the car brakes I.e red cars need bigger brakes due to the fastness nah...anyway. I had the rear rotors skimmed brakes worked fine then, we had the calipers off the car and someone unknownly pumped the brakes popped the pistons out so I opened the bleeder up and pushed them back in surely enough the brakes went soft and few days later I got mates around and we bled the brakes as he was pumping I asked him to hold the brakes in place I opened the bleeder before I started to close them he started pumping them again, stopped right away.Tonight the brakes really started to piss me off so jacked the car up we started the pump the brakes I opened the bleeder and no fluid exited the bleeder and now the brakes hardly work WHATTT?????????? HELP pleaseRegardsDaniel Link to comment https://www.fordxr6turbo.com/forum/topic/85081-help-weird-brake-issues/ Share on other sites More sharing options...
jas98 Member 1,049 Member For: 12y 10m 30d Gender: Male Location: Maryborough Qld Posted 27/05/13 02:12 PM Share Posted 27/05/13 02:12 PM sounds like you have a sh*t load of air in it, keep opening bleeder and everntually fluid will come out, may take up to 5 even ten times before any fluid comes out depending on how much air is in it. Link to comment https://www.fordxr6turbo.com/forum/topic/85081-help-weird-brake-issues/#findComment-1393164 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 29d Gender: Male Location: Probably above atmospheric pressure Posted 28/05/13 06:00 AM Share Posted 28/05/13 06:00 AM Maybe get a speed bleeder kit, one of those things that have valves so you can just attach it to the bleeder fitting, pump away while pouring new fluid into the reservoir? Link to comment https://www.fordxr6turbo.com/forum/topic/85081-help-weird-brake-issues/#findComment-1393312 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 5m 13d Gender: Male Posted 28/05/13 09:32 AM Share Posted 28/05/13 09:32 AM On 28/05/2013 at 6:00 AM, -SteveR- said: Maybe get a speed bleeder kit, one of those things that have valves so you can just attach it to the bleeder fitting, pump away while pouring new fluid into the reservoir?also fire your mate, or urself lol Link to comment https://www.fordxr6turbo.com/forum/topic/85081-help-weird-brake-issues/#findComment-1393383 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 5m 4d Gender: Male Location: Christchurch, New Zealand Posted 28/05/13 09:43 AM Share Posted 28/05/13 09:43 AM Äs above sounds like youve just got air in the system and need to do a proper bleed without any stuff ups. Link to comment https://www.fordxr6turbo.com/forum/topic/85081-help-weird-brake-issues/#findComment-1393389 Share on other sites More sharing options...
phantom xr6t Talks Cheap, Let's Race Member 596 Member For: 18y 7m 7d Gender: Male Location: Atherton, FNQ Posted 28/05/13 09:57 AM Share Posted 28/05/13 09:57 AM you did put more fluid in the master cylinder when you were bleeding right? Link to comment https://www.fordxr6turbo.com/forum/topic/85081-help-weird-brake-issues/#findComment-1393402 Share on other sites More sharing options...
Danxr Member 67 Member For: 16y 7m 13d Gender: Male Location: Perth WA Duncraig / Wanneroo Posted 28/05/13 12:33 PM Author Share Posted 28/05/13 12:33 PM alright cheers for the advice tried it all no luck so I stripped apart the master cylinder surely enough the rear brake piston seal is stuffed, we purchased a new one but was the wrong one ahhh..... so does anyone is Perth have the B227-114 it has the DSC and traction control completely different to the B227-109 Link to comment https://www.fordxr6turbo.com/forum/topic/85081-help-weird-brake-issues/#findComment-1393462 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 30d Gender: Male Location: Perth Posted 28/05/13 02:10 PM Share Posted 28/05/13 02:10 PM You over stroked the mc due to air in the system hence the torn seal. Just got Perth brake parts to reseal it for you. Link to comment https://www.fordxr6turbo.com/forum/topic/85081-help-weird-brake-issues/#findComment-1393473 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 29d Gender: Male Location: Probably above atmospheric pressure Posted 29/05/13 06:19 AM Share Posted 29/05/13 06:19 AM Over stroking is quite a hazard when there's only air and no lubricant/fluid, as above. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85081-help-weird-brake-issues/#findComment-1393659 Share on other sites More sharing options...
Danxr Member 67 Member For: 16y 7m 13d Gender: Male Location: Perth WA Duncraig / Wanneroo Posted 30/05/13 02:32 PM Author Share Posted 30/05/13 02:32 PM Thanks all got a new master cylinder yesterday fitted all sweet new fluid supplying all the brakes Yellow sticked removed Link to comment https://www.fordxr6turbo.com/forum/topic/85081-help-weird-brake-issues/#findComment-1394356 Share on other sites More sharing options...
