ronski123 Member 66 Member For: 15y 3m 23d Posted 21/05/13 03:42 PM Share Posted 21/05/13 03:42 PM Hey fellas I see there is a lot of guides for xr6 turbos but can't really find anything for the fg f6 I know there fairly similar.I was looking to try and achieve 350kw's Intercooler, injectors??, cat? ?, dump pipe??, these are the mods I was thinking not sure on the ones with questition marks sizes or if they need to be replaced to make 350 also valve springs? ? Link to comment https://www.fordxr6turbo.com/forum/topic/85014-fg-f6-looking-for-350kws/ Share on other sites More sharing options...
YOZ-F6 Member 96 Member For: 14y 8m 8d Gender: Male Location: Perth, WA Posted 22/05/13 01:04 AM Share Posted 22/05/13 01:04 AM Start with a full turbo back exhaust and go from there. The place I went to also installed new injectors, fuel pump, and some wastegate modifications, plus a tune. You'll need a tune regardless of what you do, so better to do it all in one hit, then you only pay for a single tune. Depending on the tune, and how much boost you want to run, you should be able to get around the 350rwkw mark. Depending on where you go for your modifications, you will be looking at around $5k + including all the parts and labor. so budget well, as from what I understand, some tunes cost around the $1000 mark every time you take it there..again this will be dependant on the arrangement you have with your tuner!Good luck! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85014-fg-f6-looking-for-350kws/#findComment-1391698 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 7m 29d Gender: Male Location: Zombie Birdhouse Posted 22/05/13 01:46 AM Share Posted 22/05/13 01:46 AM If the tuner did the mods no way would you pay a grand for tune alone unless there are unrelated car issueswhich required an inordinate amount of diagnostic hoursEven then I would not expect to pay that. Market dictates you should pay around $1700+ for Xcal3 and 3 tune slotseg. Valet.,95 ron and big gun tune.A tickle for minor upgrades from the same tuner to hardware should still let you go home panties intact 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85014-fg-f6-looking-for-350kws/#findComment-1391719 Share on other sites More sharing options...
YOZ-F6 Member 96 Member For: 14y 8m 8d Gender: Male Location: Perth, WA Posted 22/05/13 02:01 AM Share Posted 22/05/13 02:01 AM On 22/05/2013 at 1:46 AM, Buf-Phoon said: If the tuner did the mods no way would you pay a grand for tune alone unless there are unrelated car issueswhich required an inordinate amount of diagnostic hoursYep, that's pretty much what happened to me here in the west (go figure!) There was miscommunication between the tuner and the guy who did the modifications. So the tune was around $1000 for the day, and still had to go back a few times because of boost spiking issues!Luckily I didnt need to pay for the other times it went back! Link to comment https://www.fordxr6turbo.com/forum/topic/85014-fg-f6-looking-for-350kws/#findComment-1391725 Share on other sites More sharing options...
knoles Donating Members 390 Member For: 14y 1m 1d Gender: Male Location: Port Hedland Posted 22/05/13 02:20 AM Share Posted 22/05/13 02:20 AM Build date will also play a part in it. XFT put up a pic of a tune only fg f6 325kws and I asked is that average or is if it was a bit stronger than others and he reckons average for them if they are after a certain build date. Id be so stoked with that. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85014-fg-f6-looking-for-350kws/#findComment-1391727 Share on other sites More sharing options...
ronski123 Member 66 Member For: 15y 3m 23d Posted 22/05/13 03:09 PM Author Share Posted 22/05/13 03:09 PM I thought you didn't really need to touch the exhaust to much On 22/05/2013 at 2:20 AM, knoles said: Build date will also play a part in it. XFT put up a pic of a tune only fg f6 325kws and I asked is that average or is if it was a bit stronger than others and he reckons average for them if they are after a certain build date. Id be so stoked with that.Really what build date? ? Mines a 2012 I would be stoked with just a tune and hitting 325Also how much boost can you run through the f6 turbo? ? Link to comment https://www.fordxr6turbo.com/forum/topic/85014-fg-f6-looking-for-350kws/#findComment-1391948 Share on other sites More sharing options...
YOZ-F6 Member 96 Member For: 14y 8m 8d Gender: Male Location: Perth, WA Posted 23/05/13 02:12 AM Share Posted 23/05/13 02:12 AM On 22/05/2013 at 3:30 PM, ronski123 said: Also how much boost can you run through the f6 turbo? ?I was running 19psi with the factory dump valve, but it was boost spiking quite badly, so it was de-tuned back to 17psi..but I have since replaced the blow-off but have not been back for a tune..can't justify the $1000 for just a gain of only 2psi or more!When I save up a bit more cash, I'm thinking of replacing the stock cooling system to eliminate the heat soak issue, as recommended by XFT, and I'll have her re-tuned then!! Link to comment https://www.fordxr6turbo.com/forum/topic/85014-fg-f6-looking-for-350kws/#findComment-1392056 Share on other sites More sharing options...
ronfgf6129 Member 12 Member For: 11y 10m 22d Gender: Male Location: Perth Posted 31/05/13 04:46 AM Share Posted 31/05/13 04:46 AM Hi all, that might have been my fg f6 at Xtreme, mine is a 2010 dec euro 4 and stock it put out 285rwkw, and just a tune, and doing some thing to the cat. It put out 325 rwkw, as u can amagin I was wrapped. I have the dyno sheet to prove it. The car has done 40,000kms Link to comment https://www.fordxr6turbo.com/forum/topic/85014-fg-f6-looking-for-350kws/#findComment-1394431 Share on other sites More sharing options...
fatz_f6_typhoon Member 395 Member For: 12y 3m 16d Gender: Male Location: 2145 nsw Posted 31/05/13 04:51 AM Share Posted 31/05/13 04:51 AM Get some e85 into her and a retune Link to comment https://www.fordxr6turbo.com/forum/topic/85014-fg-f6-looking-for-350kws/#findComment-1394432 Share on other sites More sharing options...
ronfgf6129 Member 12 Member For: 11y 10m 22d Gender: Male Location: Perth Posted 31/05/13 05:09 AM Share Posted 31/05/13 05:09 AM Hi fatz I fairly new to the turbo experience. What will E85 do?Yes Simon from Xtreme was saying the euro 4 were that little bit quicker, he said next mods for me would be intercooler and injectors and I should get at least 350rwkw. I don't understand how other people say to do other things first, like exhaust and cold air, strange !!! Link to comment https://www.fordxr6turbo.com/forum/topic/85014-fg-f6-looking-for-350kws/#findComment-1394441 Share on other sites More sharing options...
