  • Member For: 13y 8m 19d
You'll find u probably need a retune as the fg head will flow better then the ba/f one and the cams are also a touch different, as I'm pretty sure fg cams are duo phased. your tuner should be able to copy the cam timing tables from an fg to urs which should help/fix
Yeh def need retune, it's running like a dog at idle once it goes into closed loop/warmed up. Hopefully it's just the cam differences etc as it does run like its got massive lumpy cams haha
  • 3 weeks later...
