Cameron02 Member 164 Member For: 12y 4m 11d Posted 18/05/13 07:08 AM Share Posted 18/05/13 07:08 AM Hi good people,My car (BA) is booked in for a tune on Monday morning. I am busy fitting Venom Cat Pipe and I also need to remove my turbo, manifold and dump pipe. I have a port/flapper turbine which has been ceramic coated as have the dump and manifold. Will also be fitting 12psi actuator once the turbo is off. I read mrmackie's post on removing the turbo which has been a big help.However, I have hit a hurdle. I am having great difficulty removing the lower compressor pipe and the compressor vac line. I managed to move the clip on the pipe (bastard) but the pipe just wont come off. I have tried grabbing hold of it from under the car and using my body weight but it wont budge. I have tried getting a screwdriver into the pipe from the top but not having any luck. Having a similar problem with the vac line. just wont budge.Any body have any tips or ideas? They are the original (standard) pipes. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84960-help-removing-hoses-from-turbo/ Share on other sites More sharing options...
Azid Member 213 Member For: 13y 7m 2d Posted 20/05/13 04:44 AM Share Posted 20/05/13 04:44 AM try heating the hose up Link to comment https://www.fordxr6turbo.com/forum/topic/84960-help-removing-hoses-from-turbo/#findComment-1390978 Share on other sites More sharing options...
