n/axr6ute Member 58 Member For: 15y 3m 25d Posted 14/05/13 02:24 AM Share Posted 14/05/13 02:24 AM Hey guys, just wondering if anyone has experienced a noise from the rear of there ute, it sounds like something is out of round, like a wooping sound, im thinking (hoping) that some weights have fallen off the rim, not sure if that would have this affect though, any info would be great before I start puling stuff apart, thinking it could be a bent drive shaft? not sure, utes only N/A didnt think it would have the balls to do that, I dunno.Cheers, sam. Link to comment https://www.fordxr6turbo.com/forum/topic/84920-noise-from-rear-end/ Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 24d Gender: Male Location: SW Sydney Posted 14/05/13 10:36 PM Share Posted 14/05/13 10:36 PM Low or high speed? All your wheel nuts on tight? (don't laugh, it does happen...)Tyres in good condition? Possible to be wheel bearings but without more information or hearing the noise it is very hard to diagnose online Link to comment https://www.fordxr6turbo.com/forum/topic/84920-noise-from-rear-end/#findComment-1389424 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 9d Gender: Male Posted 15/05/13 12:29 AM Share Posted 15/05/13 12:29 AM (edited) Tyres as mine makes the same noise... Everything was checked and Ford put rims from a new car and noise went away.. Put my wheels back on with very worn tyres and noise came back.. It's getting louder as rear tyres are wearing out pretty quickly.. Factory Dunlops are no good once worn out. Edited 15/05/13 12:30 AM by WOGPOT Link to comment https://www.fordxr6turbo.com/forum/topic/84920-noise-from-rear-end/#findComment-1389445 Share on other sites More sharing options...
n/axr6ute Member 58 Member For: 15y 3m 25d Posted 15/05/13 07:37 AM Author Share Posted 15/05/13 07:37 AM hmm, well I have my stock wheels which I am in the process of fitting now, yeah my nuts are tight that was the first thing I checked when the noise appeared.. the tyres are at about 50% treade and look in great shape, I dont do any circle work or anything, weird it just started doing it one day. the noise isnt really loud enough to take a recording of, but I can feel it a bit through the car, its very noticable at 80, and when I slow to 60 with my foot slightly on the brake pedal it seems to get a bit worse before getting better, im thinking maybe warped discs? im not to sure, any more info you guys can give would be great, ill keep you updated with what I find with the stocko's, cheers guys Link to comment https://www.fordxr6turbo.com/forum/topic/84920-noise-from-rear-end/#findComment-1389571 Share on other sites More sharing options...
aimz rokafi New Member 23 Member For: 12y 10m 12d Gender: Male Location: sydney Posted 15/05/13 09:00 AM Share Posted 15/05/13 09:00 AM mine is making a similar noise with factory 19in dunlops with 6000km of wear. the noise seems to be worse under brakes. esp just before coming to a complete stop. no vibrations through the wheel, just sounds like ive got mud tyres on hahaha. (well, not that bad) Link to comment https://www.fordxr6turbo.com/forum/topic/84920-noise-from-rear-end/#findComment-1389593 Share on other sites More sharing options...
n/axr6ute Member 58 Member For: 15y 3m 25d Posted 16/05/13 02:10 AM Author Share Posted 16/05/13 02:10 AM changed to my stocko's last night and it didnt change a thing, I will probly look at it again on the weekend and let use know, thanks Link to comment https://www.fordxr6turbo.com/forum/topic/84920-noise-from-rear-end/#findComment-1389786 Share on other sites More sharing options...
aimz rokafi New Member 23 Member For: 12y 10m 12d Gender: Male Location: sydney Posted 18/05/13 09:42 PM Share Posted 18/05/13 09:42 PM sorry, I meant; the noise seems worse when slowing down, under brakes/using the gears or just coasting. Link to comment https://www.fordxr6turbo.com/forum/topic/84920-noise-from-rear-end/#findComment-1390547 Share on other sites More sharing options...
M_crisp Donating Members 259 Member For: 14y 1m 25d Gender: Male Location: Adelaide Posted 19/05/13 12:00 AM Share Posted 19/05/13 12:00 AM My ute made a whole bunch of weird noises on wheel rotations and it turned out to be loose handbrake cable,In saying that I replaces one of the rear wheel bearings 3 times.Is your handbrake tight? Link to comment https://www.fordxr6turbo.com/forum/topic/84920-noise-from-rear-end/#findComment-1390572 Share on other sites More sharing options...
n/axr6ute Member 58 Member For: 15y 3m 25d Posted 20/05/13 02:14 AM Author Share Posted 20/05/13 02:14 AM Hey guys, ended up being a bubble in my front left tyre, found it while changing my rotor's on the weekend, its weird how it felt like the rear, when it was actually the front, ended up having a win with the roto's anyway as they were shagged, thanks for the replies guys Link to comment https://www.fordxr6turbo.com/forum/topic/84920-noise-from-rear-end/#findComment-1390920 Share on other sites More sharing options...
