80OMA Member 8 Member For: 14y 11m 24d Gender: Male Location: Toowoomba Posted 13/05/13 01:18 PM Share Posted 13/05/13 01:18 PM Hey folks probably not the right place to post this so my apologies in advance.My 2009 FG F6 with the 6 speed ZF trans likes to stall out on me when coming to a stop.Dosnt happen all the time but happens once or twice on a 20 min drive through town.Car is X cal 3 tuned with supporting mods making around 520rwhp.Any Suggestions would be greatly appreciated.Cheers Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 6m 12d Posted 14/05/13 12:31 AM Share Posted 14/05/13 12:31 AM (edited) Could the problem be related to the throttle body?...Maybe give it a clean? Edited 14/05/13 12:31 AM by boost69 Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 8m 1d Gender: Male Posted 14/05/13 05:49 AM Share Posted 14/05/13 05:49 AM There is a FG stalling problem thread that this should be combined with.I used to have this problem but not sure how I fixed it or if its really fixed but hasn't stalled for ages.I did find that my throttle plate was misalligned and would stick closed. Found this only after I bought another second hand throttle body. I did fix the throttle plate alignment by unscrewing the screws enough to reallign the plate and retighten. You just need to back off the screws a little to reallign.But I put the new T/B in and it certainly did improve something but maybe wasn't entirely the issue as it did stall under one particular condition but rarely.I then disconnected the power steering switch plug (located close to the pump) as I heard this can cause issues. You cant buy this special switch (its not really a switch in the strict sense), it only comes with the hose at $263. So I just left it unplugged. It did raise the idle about 100 rpm but I have had no stalling at all since.Previously when I raised the idle via the ECU it would still stall.So try disconnecting the power steering switch and just see how you go. Please report back as a few have had this problem and we are trying to narrow it down. Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,430 Member For: 14y 11m 6d Gender: Male Location: Melbourne Posted 14/05/13 06:25 AM Share Posted 14/05/13 06:25 AM 8OOMAwhat fuel are you using Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 6m 20d Gender: Male Location: Gold Coast Posted 19/08/13 08:22 AM Share Posted 19/08/13 08:22 AM (edited) Ford do sell the power steer switch separately now - not just with the whole hose kit at like $265 trade! Mine developed a leak over the weekend and have had a slight pulse at no load idle on and off. New switch has fixed both issues Cost me $19.36 trade price today. Fitted in 10 minutes - easy as. Edited 19/08/13 08:23 AM by Bomber Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 8m 1d Gender: Male Posted 19/08/13 09:41 AM Share Posted 19/08/13 09:41 AM Bomber, could you please write out that part number as its a bit hard to read.Thanks for posting that. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 6m Gender: Male Location: Adelaide Posted 19/08/13 10:02 AM Share Posted 19/08/13 10:02 AM Iirc the p/s only bumps idle up 50rpm, mine let go along time back a bolt now lives in its place This sounds like the t/b needs a good clean and go from there Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 1m 12d Posted 19/08/13 11:23 AM Share Posted 19/08/13 11:23 AM What fuel pump are you running and how much fuel pressure? I recently had problems with my new surge and ID1000's. Had 100psi at idle and was causing the car to stall once warm, possibly something to look into, dropped it down to 55psi with a turbosmart fuel reg and so far so good for now Link to comment Share on other sites More sharing options...
