500Rwkw Advice
JK89
  • Member For: 14y 1m 8d
Hey guys just want some adivce tips hints etc on my build
currently im running 410rwkw with the following mods on a BA ute
fully built engine with cosworth pistos and atomic rods
atomic race girdle
atomic billet oil gears
race bearings through out (forgot brand :\)
Atomic 4.5 cams
atomic valve springs
mls head gasket
engine is fully balanced and blueprinted
t56 gearbox w/ npc 6spot clutch
billet zp turbocharger with external gate welded off exhaust housing
dual 044 setup with 2.5l surge tank
650cc injectors
std manifolds
process west 4" race intake system
process west stage 3 intercooler with 3" cold 2.5" hot piping
now im changing -
6boost lowmount manifold with 48mm wastegated flange
1000cc injectors
Upgrading my turbo to a project test turbo from a reputable company (capable of well over 500rwkw but using std rear housing obviously modded to suit larger wheel combinations)
upgraded fuel reg + modified fuel rail
what will be my downfalls obviously my intake manifold (plenum) is not ideal I get that but can anyone maybe help estimate what I would be looking at for powerwise either e85 or 98 pump??
any positive feedback would be appreciated!
  • Member For: 15y 2m 22d
It's a bit hard without the specs of the turbo, any hints on what garret/precision turbo this may be close too?
Just out of interest, are you running the atomic vernier timing gears or stock variable setup? Are you running the stock fuel reg with 2 x 044 pumps?
  • Member For: 18y 7m 22d
^^^^agree need to know more about the turbo specs!!
The rest of the mods look fine and being a manual the dyno figures should be on your side,if you have the turbo that's capable..450rwkw on 98 should be achievable quite easily at around 20psi and the sky's the limit on e85 especially if he turbo is capable of big boost!
Lee
yeah mate running atomic vernier timing gears and yes a new generic fuel reg will be used ( any hints on brands and prices etc?)
turbo im not even sure of! haha hes a good mate of mine building a complete custom one and wont tell me anything lol.
the last custom setup he made was in a std ford rear housing with a custom billet hi flow compressor wheel - produced 460-470rwkw (complete drop in turbo no modifications to lines covers etc)
so im not sure if its gonna be the sme size or roughly like a t51r or a custom t04z setup with a custom machined larger front compressor wheel. so I wish I knew once I know more about the setup I can share - but its all secret squirrel at the moment im not being told anything which is annoying in one aspect but exciting in the other
