  • All stock bar the k&n panel filter
  • Member For: 13y 3m 20d
That'd make our next rent inspection interesting...
  • Member For: 16y 11m 17d
22 hours ago, Ralph Wiggum said:
You've got a lounge room yeah? Priorities Son.
Kitchen FTW.
  • Like 2
I've had a Kawasaki Balius sitting in storage for about seven years, and figured it was about time I got it back on the road again.
Why the fuss about a 250?  Instead of the usual boring single or twin-cylinder, this one's a high revving four-cylinder.  Redlines at 18,000rpm, and sounds like a Formula 1 engine.
Heaps of rust in the fuel tank.  Bugger.
Did the usual Google searching to find a solution, and found that heaps of people have had success with electrolysis.  Ok, I'll give that a go - it's the cheapest option.
Nup, fail.  Can't get it to work consistently.  Got a little bit of rust out, but not much.
I'll figure it out sooner or later.  And yes, I actually have been looking for a ways of replacing the standard two-piston Tokico caliper with a four-piston Brembo one.
Build thread:  http://2fiftycc.com/index.php?threads/reminiscing-about-my-old-balius.8630/
Edited by PhilMeUp
  • Like 3
  • Will do skids for food
  • Member For: 13y 7m 29d
I've previously tipped a hand full of nuts and bolts in a tank and then shook the sh*t out of it.
Your rust issue is a lot more severe though.
I also used a two part sealant that gets poured in and you just turn the tank over and over so it coats all the surfaces.
So far its still holding up....I think.
  • MattyP
  • Cruise Control
  • Member For: 13y 1m 29d
Thinking about getting into the bike game again
I've owned a gsx250f across and a gsx650
I miss the 650 a lot
Such a nice bike to ride through the twisted and torque for days
Got my engine back, threw it back in the bike and will finish off the install today.
Now I just need to make a final version of the battery/cdi box at the front and it's about ready to get the new wiring harness made.
I also collected this last night.
Hopefully with the new Link ECU and CDI in the bike next season, I can get the bike to perform more consistently and I can finish higher up the order next season.
  • Like 5
  • skids
  • Member For: 12y 6m 5d
  • Gender: Not Telling
TANK RUST? far out I've never had so much trouble until I came across this R1 tank! bike had been sitting for a few years but still.
-started off using a kit where you clean the tank out, shake nuts and bolts around then put this sealant stuff in. fail after a week.
-took it to professional who welded it all up on the cheap. fail straight away, lucky tank wasnt full.
-took it back to professional who pressure tested it and found heaps of holes now it's all fixed.
the reason I say it was so much trouble is draining the tank takes ages.
your bike looks sick mate, something about a bike with no fairings on that gets me all revved up ;)
I took the day off work Friday and spent it at the paint shop prepping everything for primer.
Today I just need to do the wheels and finish the new fairing and besides a couple of spots of knifing putty, it'll be all done.
A fair bit of work in all that but it was good therapy to just switch off and sand stuff down and try not to think about work.
Coincidentally I discovered rust in the K6 tank so I bought a sealing kit yesterday and will do the old nuts and bolts trick first and then seal it.
Tip 1. Use steel nuts and bolts, not stainless, so you can fish the pesky buggers out with a magnet.
