GSP07R Member 248 Member For: 11y 10m 25d Gender: Male Location: Western Syd Posted 10/05/13 03:30 AM Share Posted 10/05/13 03:30 AM If it's not to big or heavy free frieght could happen. Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 10m 14d Gender: Male Location: Christchurch, New Zealand Posted 10/05/13 04:35 AM Share Posted 10/05/13 04:35 AM Atomic do a stud or bolt kit with locks so they don't undo. Otherwise you can always drill bolt heads and lockwire them. Link to comment Share on other sites More sharing options...
jas98 Member 1,030 Member For: 12y 4m 9d Gender: Male Location: Maryborough Qld Posted 10/05/13 01:14 PM Author Share Posted 10/05/13 01:14 PM I have no idea haw to safty wire em hahacan I tack weld the studs in there? or is there no room?if hat makes sence?then ill use some of those locking nuts that are made from copper?? Link to comment Share on other sites More sharing options...
shanoplata Member 19 Member For: 11y 6m Posted 22/12/13 01:50 AM Share Posted 22/12/13 01:50 AM Can anyone please give me any tips on fitting the Nizpro kit, it has 4x s/steel studs, 1x turbo gasket and 4x lock nuts. The kit was $212.00 and I dont want to screw it up. Also any info on re-installing the turbo in regards to sealent use would be great. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 1m 5d Gender: Male Location: Perth Posted 22/12/13 01:57 AM Share Posted 22/12/13 01:57 AM Just remove old studs and install new ones, fit gasket and then turbo, nuts and tighten.Hows about a pic of the kit.You can butcher the old studs as your not using them again. Fine thread goes into the manifold. Link to comment Share on other sites More sharing options...
shanoplata Member 19 Member For: 11y 6m Posted 22/12/13 03:26 AM Share Posted 22/12/13 03:26 AM I'm having trouble putting a photo on here. I think I spoke to you a while ago about trouble I was having with my turbo on the forum. I removed my old turbo and found cracks in 3 of the turbo exhaust housing bolt holes so I bought a replacement turbo from ebay that come off a typhoon ute, the seller stated that it had been ported with upgraded flapped but the wastegate hole looks to be unmodified although the flapper is upgraded and has a tag. I took the original turbo off about 3-4 months ago and now want to put it all back together.A few specific questions I have:Do I need to lock 2 nuts on the turbo/exhaust manifold studs to install them tightly? and does the same apply for the exhaust/ dump pipe to turbo studs?Should I use locktite/sealant on any areas upon installing the turbo? (I noticed some sealent on the oil return line from the turbo to the sump).I understand that the turbo runs very high temperatures, I am installing an Earls oil supply line with filter and was wondering if any loctite should go on the new oil line connection threads that go into the turbo body.Although I have searched on the forums I cant find a good step by step on re-installing the turbo.I really appreciate any info/tips on the re-installation. Link to comment Share on other sites More sharing options...
shanoplata Member 19 Member For: 11y 6m Posted 22/12/13 03:44 AM Share Posted 22/12/13 03:44 AM I added the pic in my av/photo as it seemed like the easiest way Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 10m 14d Gender: Male Location: Christchurch, New Zealand Posted 22/12/13 04:48 AM Share Posted 22/12/13 04:48 AM Yea just use 2 nuts (not the ones supplied so they stay in good nick) to install the studs. Installing the turbo is reverse of the taking out that you've done, it is pretty simple. Link to comment Share on other sites More sharing options...
jas98 Member 1,030 Member For: 12y 4m 9d Gender: Male Location: Maryborough Qld Posted 23/12/13 02:49 AM Author Share Posted 23/12/13 02:49 AM $212? wtf are they made of? my kit was $18 and its never come loose to date!....am I mising the point? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 2m 9d Gender: Male Location: Perth Posted 23/12/13 03:40 AM Share Posted 23/12/13 03:40 AM I'd be tipping the Studs are Inconel. Link to comment Share on other sites More sharing options...
