MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 13y 1m 10d Gender: Male Location: Wollongong Posted 31/07/14 09:46 PM Share Posted 31/07/14 09:46 PM lol^^ But like you guys said, why run low boost with a billet GTX? go the whole hog. That thing has nearly the same size engine as our in a go cart, surely it wont take alot of power to run a 10. theyd do 300rwkw no worries wuldnt they? Link to comment https://www.fordxr6turbo.com/forum/topic/84830-fitting-a-barra-i6t-to-another-vehicle/page/6/#findComment-1488989 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 11d Gender: Male Location: Brisbane Posted 31/07/14 11:22 PM Share Posted 31/07/14 11:22 PM I think the 76 is probably perfect for 3.6l given it runs out off puff up top on ours. Not really low boost application though lol. Should hold 20psi you would imagine. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/84830-fitting-a-barra-i6t-to-another-vehicle/page/6/#findComment-1489002 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 1m 27d Gender: Male Location: Central Coast Posted 31/07/14 11:53 PM Share Posted 31/07/14 11:53 PM My thoughts exactly Why not go a smaller turbo and enjoy same power with more response Link to comment https://www.fordxr6turbo.com/forum/topic/84830-fitting-a-barra-i6t-to-another-vehicle/page/6/#findComment-1489008 Share on other sites More sharing options...
Woznaldo Member 28 Member For: 12y 1m 26d Gender: Male Location: South West Sydney Posted 02/08/14 11:13 AM Author Share Posted 02/08/14 11:13 AM Thanks for encouragement Tex and for the info barnz. I'll give google a go a see what I can find.Are you saying that I can't run the XF if it has come from a different car? Because the OE ECU won't talk to the XF moduleFrom another car (VIN)?I'll try to put this question in, hopefully, more basic terms. I trying to understand what different parts of the cars electrical system speak to each other in order to work.Obviously the ECU, or ECM as Ford calls it, gets feeds from all the engine sensors and in turn feeds the Tacho etc. What I don't know is what the transmission computer, or TCM, speaks to. I'm going to assume it speaks to the following:ABS module - for road speedECM - for Engine RPM, Throttle positionI think I've read something about the Instrument Cluster having some input/output function?If all of the above has been covered in another thread, please steer me in the right direction.Thanks, Woz. Link to comment https://www.fordxr6turbo.com/forum/topic/84830-fitting-a-barra-i6t-to-another-vehicle/page/6/#findComment-1489391 Share on other sites More sharing options...
Woznaldo Member 28 Member For: 12y 1m 26d Gender: Male Location: South West Sydney Posted 02/08/14 12:09 PM Author Share Posted 02/08/14 12:09 PM Ok, I've found some info from Jag PDF that sheds some light on the subject, so here's what I've got so far:3.2.1 TCM The TCM controls the operation of the transmission. The TCM processes information received in both analogue and digital form such as: • Transmission Input Shaft Speed (ISS).• Output Shaft Speed (OSS).• Throttle pedal position.• Gearshift selector position.• Engine torque.• Engine speed. • Transmission Fluid Temperature (TFT).• Brake pedal status. • Engine oil temperature.• Engine Coolant Temperature (ECT).• Anti-lock Braking System (ABS) wheel speed. This information is then used by the TCM to decide which shift pattern to select and for shift energy management. Electro-hydraulic solenoid valves and pressureregulators control the transmission gear changes. Five pressure regulators and one solenoid valve are used to control direct transmission fluid flow to select internal clutches and control the fluid pressure at the clutch. A separate pressure regulator is used exclusively for the TCC control. The TCM monitors all TCM inputs and outputs to confirm correct system operation. If a fault occurs the TCM is able to perform a default action and inform the driver of the problem, this is by the instrument pack message center. 3.2.2 Solenoids The hydraulic module contains one solenoid valve. The solenoid valve is actuated by the TCM and has two positions of open or closed, it is used to switch the position valve.There are six electronic pressure control valves, these convert an electric current into a proportional hydraulic pressure. The solenoids are energized by the TCM and actuate the valves belonging to the relevant switching elements. 3.2.3 Controller Area Network Interface For the TCM to be able to perform shift point and shift quality management a number of external signals are required. For shift point management alone the TCM requires an OSS sensor, throttle pedal position, brake pedal status and gear selector position. The Controller Area Network (CAN) bus is used to share information between control modules. The TCM obtains most of its required data over the CAN bus from the electronic engine controls, J-Gate and ABS, Instruments pack and diagnostic tools. 3.2.4 Brake Pedal Position Switch The Brake Pedal Position (BPP) switch tells the TCM when the brakes are applied, and disengages the TCC. The BPP switch closes when the brakes are applied and opens when they are released. The BPP is also used to disengage the brake shift interlock and stops gradient calculations.Jaguar Cars Revision Date: October 2003 Page 8 of 30 3.2.5 Engine Coolant Temperature Sensor The ECT sensor detects engine coolant temperature and supplies the information to the TCM. The ECT sensor is used to control the TCC operation. 3.2.6 Accelerator Pedal Position Sensor The Accelerator Pedal Position (APP) sensor is a potentiometer mounted on the accelerator pedal. The APP sensor detects the position of the accelerator pedal and sends this information to the Engine Control Module (ECM). The APP sensor is used for shift scheduling and TCC lock-up. 3.2.7 Input Shaft Speed Sensor The Input Shaft Speed (ISS) sensor is a Hall effect type sensor.The ISS sensor is mounted internally on the transmission and is located on the TCM and main control valve body unit. 3.2.8 Output Shaft Speed Sensor The Output Shaft Speed (OSS) sensor is a Hall effect type sensor.The OSS sensor is mounted internally on the transmission is used for shift scheduling. 3.2.9 Transmission Fluid Temperature Sensor The TCM utilizes one TFT sensor located on the main control valve body. The TCM uses the sensor input to activate various shift strategies. The sensor is in the form of a temperature dependent resistor.The temperature sensor performs plausibility checks on each sensor reading. Obviously, the transmission oil temperature should not jump in value excessively between sensor readings. If the inputs from the temperature sensor are outside the working range it possible that the sensor is short or open circuit. 3.2.10 Position sensor The TCM uses the position of this switch housed on the TCM and main control valve body, to determine the selected gear range on the automatic side of the gearshift selector lever.Jaguar Cars Revision Date: October 2003 Page 9 of 30 The gearshift selector lever is connected to the transmission by a cable, which operates the transmission selector shaft between positions park (P), reverse ®, neutral (N) and drive (D). The TCM detects the driver's choice of manual range selection (5,4,3,2) by means of a 3-bit code generated by the J-gate. This 3-bit code is then transformed in to a CAN message by the J-Gate module and transmitted on to the CAN bus where it is detected by the TCM. The TCM uses this information to generate the CAN message 'Gear Position Selected', which must not be confused with the similar message 'Gear Position Actual' indicating the current mechanical gear ratio activated by the TCM. Movement of the lever between park, reverse, neutral and drive manually controls the flow of transmission fluid, the TCM having control of the forward gear selected in drive. Additional movement of the lever to 5,4,3 and 2 positions does not manually modify the fluid flow, the TCM detects these positions, and controls the gear selected electronically. Full doc: http://www.europeantransmissions.com/Bulletin/DTC-jag/6hp_trans.pdf Link to comment https://www.fordxr6turbo.com/forum/topic/84830-fitting-a-barra-i6t-to-another-vehicle/page/6/#findComment-1489439 Share on other sites More sharing options...
sr71 Member 52 Member For: 11y 2m 19d Posted 02/08/14 12:40 PM Share Posted 02/08/14 12:40 PM Lots of communication and controlling actions happening there. Good thing that you have your Aircraft Technician background to make sense of it . The comment below would apply to me.The zf 6 speed would be a nightmare.But worth it. Great project! I look forward to seeing it done. It would look cool amongst the Fords, on a Cruise 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84830-fitting-a-barra-i6t-to-another-vehicle/page/6/#findComment-1489461 Share on other sites More sharing options...
Dartweb001 New Member 1 Member For: 6y 1m 23d Posted 08/05/19 01:47 AM Share Posted 08/05/19 01:47 AM Ok, I want to do the same thing to my Jag except that mine is much older, a 1959 mk9 Jaguar ex wedding car which already has a 4.1 cortina crossflow motor. I have no electronics anywhere in the car except for a single push button interior light and I am not as handy as you seem to be with the ecu stuff- I need plug and play. I want to keep my bench seat and stick shift but want more horses than currently have. Suggestions? later crossflow/ barra , could really do with an overdrive as I have a 4.27 diff ratio which makes it scream. currently my daily but it is starting to get unreliable so need to do an upgrade. This is the car before I bought it a few months ago and brought it to melb. I live next to pickles so happy to buy a wreck. Link to comment https://www.fordxr6turbo.com/forum/topic/84830-fitting-a-barra-i6t-to-another-vehicle/page/6/#findComment-1683093 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,583 Member For: 17y 2m 21d Gender: Male Location: Melbourne Posted 08/05/19 01:56 AM Share Posted 08/05/19 01:56 AM A stock/haltech is probably your best bet, then. There's still a bunch of electronics that need to be wired in, though, even though both ECU's are relatively plug and play. Link to comment https://www.fordxr6turbo.com/forum/topic/84830-fitting-a-barra-i6t-to-another-vehicle/page/6/#findComment-1683094 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 2m 9d Gender: Male Location: Canberra ACT Posted 08/05/19 04:15 AM Share Posted 08/05/19 04:15 AM When I wrecked my BA, I had a conversation with my wife about putting the motor into a Jag XJ6 and getting a number plate "LAGUAR". It was a short conversation.The security stuff on the factory ECU can easily be disabled so that you dont need to run the associated body control hardware and is definitely a cheaper option than a Haltech. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84830-fitting-a-barra-i6t-to-another-vehicle/page/6/#findComment-1683097 Share on other sites More sharing options...
Dartweb001 New Member 1 Member For: 6y 1m 23d Posted 20/05/19 07:06 AM Share Posted 20/05/19 07:06 AM Thanks disabled sounds better (cheaper) to me. are there any kits for mating these up to 1959 technology? Link to comment https://www.fordxr6turbo.com/forum/topic/84830-fitting-a-barra-i6t-to-another-vehicle/page/6/#findComment-1683764 Share on other sites More sharing options...
